Gearbox/clutch problem, please help
Old Feb 19, 2007 | 08:23 AM
matts1's Avatar
matts1
Default Gearbox/clutch problem, please help
Hi,
I have a problem with the clutch on a 1.8 TD N plate escort.
The clutch arm on the gear box is loose, it attached to the gear box on a spline that comes out of the box.
It is secure to the spline, but the spline itself is loose and wobbling about
There is also vurtually no clutch pedal, tiny bit, and it vibrates when pressed down?
Do I need to replace the clutch, and this spline thingy, can it be fixed without removing the box?
Please let me know if you have any idea's.
Matt
Old Feb 19, 2007 | 01:18 PM
SafeChav's Avatar
SafeChav
Theres usually a plastic bush that pushes in the top of the gearbox housing, its probably worn or missing
Old Feb 19, 2007 | 01:22 PM
matts1's Avatar
matts1
seen that and it does look preished, so if i pop the arm off can i just take that out and drop a new one in or does the box need to come out?
Old Feb 19, 2007 | 01:25 PM
SafeChav's Avatar
SafeChav
Being the later type release fork you will probably get away with taking the arm off and levering it out. And by the way, the rubber cap is seperate, one thats off you should see a white nylon sleeve
You'll have to hope the bottom locator within the box isn't worn, if it is that will be a new casing needed
Old Feb 19, 2007 | 01:28 PM
matts1's Avatar
matts1
that sounds worrying as you can wobble that spline like it is a spoon in porridge, deffo the bottom of that spine is free
Old Feb 19, 2007 | 01:32 PM
SafeChav's Avatar
SafeChav
For what its worth id check that nylon sleeve out mate, the bottom hole isnt going to be a 100% tight fit as you have to angle the fork in to the hole when you fit it.
The casing is only aluminium though, so its going to be prone to wear if its not greased up
Old Feb 19, 2007 | 01:35 PM
matts1's Avatar
matts1
cheers fella, does the sleeve pull out?
Old Feb 19, 2007 | 01:39 PM
SafeChav's Avatar
SafeChav
Yea, might be a bit of a slag though
Old Feb 19, 2007 | 01:45 PM
matts1's Avatar
matts1
I feel the cheap sale of an escort with clutch issue coming on very soon
Old Feb 19, 2007 | 01:47 PM
SafeChav's Avatar
SafeChav
If its got an engine smaller than 1.5 ill have it
Old Feb 19, 2007 | 02:19 PM
matts1's Avatar
matts1
No, it's a 1.8TD I am affraid, but Ł375 as is and he may well be inclined to let it go
SafeChav's Avatar
SafeChav
Nah im after something thats cheap to tax
Old Feb 19, 2007 | 02:27 PM
matts1's Avatar
matts1
It is taxed, can't get cheaper than that
Mind due,your not exactly on my doorstep so would cost a bit to get it home, oh well!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
