knocking on a fresh engine
Old Feb 18, 2007 | 02:14 PM
bassy_g's Avatar
bassy_g
Default knocking on a fresh engine
this has been getting at me for a while but in my shed i have an engine i removed from my old rst as it had low oil pressure at tickover and was knocking.
when i dismantled the engine the crank and shells were unmarked yet with the crank bolted in place you can still move it up and down
is this due to the wrong size bearings being used when the crank was fitted?
everything else on the engine was brand new
the engine had only done a couple hundred miles and i still have the reciept for it,was from a company named rogersports
Old Feb 18, 2007 | 04:23 PM
Jesus this is basic stuff, cannot beleive a garage can get it this wrong!!
If you can even feel any movement when tightened up(caps) they are indeed wrong shells for the crank which has presumably been reground ?
I always check turning torque required before I even pot the rest together and there is absolutely no excuse for this kind of workmanship at all.
I would meausre journal sizes, big ends and mains and then look up to see what it should be then check shell sizes.
I can only assume you have either an undersize(reground) crank or the wrong shells for the car.
Frankly I would do the job yourself than trust people that can't even put correct shells in.
ps a teeny weeny bit of endfloat is normal, but only teeny weeny bit
Old Feb 18, 2007 | 04:47 PM
gaz s1's Avatar
gaz s1
rogersports didnt the owner move to africa
Old Feb 18, 2007 | 05:24 PM
bassy_g's Avatar
bassy_g
thats what i heard too,heard nothing but bad things about the company,thankfully i didnt pay for the engine i bought the car on the cheap with it in as the shell was rotton an it wasnot running at the time.
Old Feb 18, 2007 | 05:29 PM
bassy_g's Avatar
bassy_g
i want to put new shells in as the rest of engine is otherwise spot on the pistons did not even have a buildup of carbon on yet and the bores are perfect.
thanks for clearing that up mate
so if i measure up and get the correct shells things should be spot on
Old Feb 19, 2007 | 05:33 PM
ivorbiggun's Avatar
ivorbiggun
PASS THE MONKEY WRENCH
Old Feb 19, 2007 | 05:34 PM
ivorbiggun's Avatar
ivorbiggun
DAD, DO YOU KNOW THE PIANO'S ON MY FOOT?
Old Feb 19, 2007 | 05:35 PM
ivorbiggun's Avatar
ivorbiggun
YOU HUM IT SON, I'LL PLAY IT.....................
Old Feb 19, 2007 | 06:18 PM
gee1599's Avatar
gee1599
you need to also make sure the block has not been oversized something that ford done to stop scrap blocks
mine was a bas~#*d to get the correct bearings as i needed 0.40mm oversize and 0.25mm undersize
Old Feb 20, 2007 | 05:33 PM
LeviA's Avatar
LeviA
That Rogersports had done the servicing on my old Sapphire and if that's the standard of his workmanship then he's best off in fuckin' Africa
Old Feb 21, 2007 | 06:48 AM
Best take engine to decent machine shop, thye will accurately measure the clearance, an check for ovalty, line bore is ok etc.
They will also be able to supply the bearings as a lot of bearings are interchageable with just a bit of filing on tabs etc others can be made to fit from other makes of car boatplane jcb etc, you get the picture.
Old Feb 21, 2007 | 10:43 PM
LSD's Avatar
LSD
Roger sports were proper dodgy, I drove all the way to derbyshire in the middle of knowhere to be told that my engine and turbo where F^&KED ............??? what sort of an anwser is that, so turned out that the turbo air intake pipe was colapsing on boost, (this was back in 1999 when I was quite new to the joys of RS turbos!) what a bunch of monkeys!!
and how you can not spot that sort of movment on a crank...I do not know!!
JoeyBoyden
Jan 4, 2024 02:36 PM
adam151082
Aug 30, 2015 08:34 AM
gabbo
Aug 28, 2015 03:56 PM
Dahl88
Aug 22, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
