type 9 gearbox on cosworth lump help plz?
Old Feb 17, 2007 | 09:18 AM
Punter's Avatar
Punter
From: in the workshop rebuilding my car for many years now
Default type 9 gearbox on cosworth lump help plz?
rite i have a type 9 quaife box i want 2 c if it will go on a cosworth lump any help would be great cheers
Old Feb 17, 2007 | 12:48 PM
markk's Avatar
markk
fit hydraulic clutch, will work fine, you must use a smaller flywheel though.
Old Feb 17, 2007 | 03:35 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
N/A cossie or turbo ?
If turbo i would not even bother
Steve.
Old Feb 17, 2007 | 03:36 PM
Punter's Avatar
Punter
cosworth turbo
Old Feb 17, 2007 | 05:45 PM
trevCOSS's Avatar
trevCOSS
the type 9 will be to weak even a quafe one, look at the reccomended power on the quafe iirc its about 250bhp max mabe less
Old Feb 17, 2007 | 05:46 PM
trevCOSS's Avatar
trevCOSS
and yes i know its torque that kills boxes but i dont know the figure that the quafe type 9 is good for
Old Feb 17, 2007 | 05:48 PM
markk's Avatar
markk
the quaife type 9 will be fine.
Old Feb 17, 2007 | 05:55 PM
trevCOSS's Avatar
trevCOSS
recomended from quafe the max power on there type 9 clubman syncro box is 190bhp and on the type 9 sequential boxes and full straight cut its 275bhp now I have no experience of a type 9 box on a cossie engine especially a quafe one im just telling you what i have read.
Old Feb 17, 2007 | 05:59 PM
markk's Avatar
markk
i have and trust me, it will be fine
Old Feb 18, 2007 | 12:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I would sell it and buy a cossie T5 box.
Steve.
Old Feb 18, 2007 | 01:47 PM
markk's Avatar
markk
Steve.
what ! sell a quaife type 9 for a cossie T5 , you are joking ? the T5 is a crap gearbox, the only reason people put up with its crap shift and crap ratios is for a tractor like size that makes it take biggish power.
Old Feb 19, 2007 | 03:47 PM
Punter's Avatar
Punter
it will sell ive had it up 4 sale 4 a month now,
will it work yes or no?
wat do i need 2 do
Old Feb 22, 2007 | 05:27 PM
Oddified's Avatar
Oddified
The type 9 will fit behind the cossie lump, i have a N/A cossie(plus n20, 300bhp+) running through a type 9 with tran-x gear kit. Use a cossie flywheel/clutch and the type 9 bell houseing...it does fit. Then convert it to a hydraulic clutch. The only frigging about you need to do is the starter motor, i used a lucas M85, long nose with a smaller Rover metro 9 tooth pinion gear fitted, carefully elongate the starter bolt holes to move the starter away a few mm from the flywheel/ring gear and the jobs done.
Ian.
Old Feb 22, 2007 | 05:30 PM
markk's Avatar
markk
Ian.
if you use a cossie flywheel, turn it down to suit a pinto ring gear then the short lucas starter its the std RS2000 bellhousing a treat, no mods to anything !
Old Feb 22, 2007 | 06:40 PM
Oddified's Avatar
Oddified
That's the other option(mod the flywheel), i went for the starter route because it also changes the gear ratio of the starter/ring gear giving more torque for starting a high compression engine
Ian.
Old Feb 22, 2007 | 08:59 PM
markk's Avatar
markk
cool , good point !!
mine was turning a nasp cosworth (at first at 11:1) then a lower comp turbo motor
Old Feb 28, 2007 | 05:27 PM
Punter's Avatar
Punter
i sold it guys now
but thanks for all the help
cheers again
JoeyBoyden
Jan 4, 2024 02:36 PM
CLIVE
Oct 2, 2015 12:58 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
