genuine rs 500 8 injector manifold for sale
as in title. removed from my own sapphire in good working order. i have been told it has had flow work inside and it has been machined around the throttle body to stop the inlet pipe coming off. it has a 4x4 tps and all other bits you can see attached. theres 2 earoquip attachments on the top fuel rail. 1 for main fuel in and the other for a feed to a NOS system which can be capped off if not needed. braided pipes and reg included. available with or without injectors.
call Adam on 07968545399.
£1200 as is.
£1400 with 8 x 803 greens.
£25 insured delivery.
sensible offers considered.
RIB1122
Aug 12, 2015 08:51 PM
