help cant get in boot!!
jus wonderin if any 1 can help me, i cant get my boot open 2 get my tools out, it wont open wen i push the lock in, it jus pushes in but wont open, i cant pull the back seats down because i need 2 pull the cable/nob thingy from the boot ( its a cabriolet) for the back seats 2 cum down, any ideas or tricks as i need help asap, cheers in advance
the bottom of the rear seats is just thight with 2 screws.
just get that out of the way, and then drag the wire and the rear seats goes down.
did not find any pics of the car to show
cheers 4 the replys an suggestions, jus discoverd a easy way off http://www.escortcabrioletclub.co.uk,
a fellow cabriolet owner told me 2 pull the carpet off the back shelf an pull off a plastic cover an put your hand threw the hole an tug the cable....an hey presto the seats came down, jus thought id tell ya jus incase anybody else wiv a rst cabriolet on here has the same problem
not sure wats wrong with my lock/boot tho, the key locks/unlocks the lock an pushes in but it wont open upwards??
chris m1
Sep 7, 2015 08:02 PM
