Very Quick question
Old Feb 14, 2007 | 09:17 PM
MJ_RST's Avatar
MJ_RST
Default Very Quick question
can nebody help me with the whole twin turbo set-up as its bugging me how it works?
Prob a stupid quest but itl bug me till i find out how they work dif to a single turbo set up (obv its got an extra turbo tho!)
Old Feb 14, 2007 | 10:31 PM
bud-weis's Avatar
bud-weis
Football Cwazy
which engine in particular are you thinking of?
Old Feb 14, 2007 | 11:08 PM
khanny's Avatar
khanny
i dont know much about it but my m8s got a mazda rx7 twin turbo i know that the first turbo kicks in nearly straight away followed by the second furthur up the revs
Old Feb 15, 2007 | 08:52 AM
JesseT's Avatar
JesseT
It's often referred to as a turbo compound setup, altough that term is used for many different setups including two turbine stages.
In short:
Exhaust gases drive the turbine of the smaller turbo. After that the exhaust gases drive the turbine of the larger turbo. The smaller one need to have a large wastegate.
The cold air intake goes first to the compressor of the larger turbo and then through the compressor of the smaller turbo. The to the engine via an intercooler.
Now, at low revs, the engine practically works as it only had the small turbo. When the revs rise, the wastegate of the small turbo will be wide open, and the larger turbo is spinned up. The boost is now built by the two compressor stages makin gthe system go further up and also more efficiently.
Old Feb 15, 2007 | 04:08 PM
MJ_RST's Avatar
MJ_RST
I see, i thought that was just the bi-turbo's on the likes of audis that one kicks i early.
Im thinking in general, as i dont understand the whole twin set up really.
So can any single turbo car be set up to run twin turbo then?
i know turbo technics used to do the twin turbo conv.
Again, ne info much appreciated
Old Feb 15, 2007 | 04:39 PM
MarkN's Avatar
MarkN
I think the turbo technics conversion you are thinking of is totally different. As I recall it was fitted to v6/v8s and you had two identical turbos - one on each bank.
They weren't interconnected in the way described above...
Old Feb 16, 2007 | 01:58 PM
MJ_RST's Avatar
MJ_RST
Ah i see, i thought that a twin turbo set up was two identical spec turbo's to begin with and that a bi-turbo set-up was the one kicking in on low revs etc..
How was the turbo tech system modified to fit?
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
