1.8 zetec Turbo Engine - SOLD
Feb 14, 2007 | 09:41 AM
Newly rebuilt 1.8 zetec using standard pistons etc i was going to run a
de-comp plate 2.5mm think to drop the ratio.
EFI inlet Light blue injectors
Sump has been tapped for oil return
Supplied with T3 turbo which needs a rebuild
RST exhaust manifold all tapped and plugged
130 spec cams
New Cam belt and pullies
I never had time or money to put back together and finish therefore i need a quick sale £300 for the lot!
It just needs putting together and wont cost the earth as most of it has
been done!
Feb 14, 2007 | 10:03 AM
Feb 14, 2007 | 01:49 PM
given up already
what now
Feb 14, 2007 | 04:06 PM
Quote:
Originally Posted by M K
given up already
what now
Not given up marc but buying a house so all projects on hold or up forsale till hay and me get settled.
I will have a ford weapon again soon hopefully
Feb 15, 2007 | 10:19 AM
Feb 15, 2007 | 10:29 PM
alright mark ill get somes pics up by tomorrow.
poastage will be possible but will be £40 and delivered on a pallet.
rob
Feb 17, 2007 | 10:41 AM
Feb 17, 2007 | 11:09 AM
other than ecu and wiring is there anything i would need to get to fit it my rs i.e stronger clutch, mounts etc
Feb 17, 2007 | 01:11 PM
not sure about mounts etc but if you go to
www.zetec-turbo.co.uk the guy on there fitted one in his s1 could be a good reference point for you.
cheers
rob
Feb 17, 2007 | 02:15 PM
ok will do cheers m8
Feb 17, 2007 | 02:17 PM
Feb 17, 2007 | 03:08 PM
where abouts in essex are you mate
Feb 17, 2007 | 03:11 PM
what loom and management does it come
Feb 19, 2007 | 10:34 AM
Turboben
Im in romford essex mate and it dosnt come with any loom or ecu.
Rob
Feb 19, 2007 | 07:32 PM
Feb 20, 2007 | 09:26 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
