scorpio problem, anyone
Old Feb 13, 2007 | 10:07 PM
jayRS's Avatar
jayRS
Default scorpio problem, anyone
father inlaw has got got a ford scorpio, all was ok yesterday, but today whenhe presses the button in on the side of the gear stick (automatic) it makes a buzzing sounds from behind the dash, and stays on in any gear, moving or not untill its put back in park.
anyone got any ideas on this?
my first thought was maybe a door was open, but they were all shut, he gunna look at the door pin switches tomorrow.
dunno if it is that or not, anyone come across this before?
if it makes any difference, the radio and no interior lights works, thats a fuse we know which will be changed but cant see that having a effect on it.
any tips as to what it could be or where to look would be good and i can pass them on to him.
cheers
Old Feb 19, 2007 | 07:35 PM
gurnE's Avatar
gurnE
Could be fookin' anything on those things
I've just bought one myself as a cheap runaround and the electric are a bit complicated to say the least.....lol
Door switches may be the best place to start; I know a buzzer sounds if the door is opened when the box isn't in P
Old Feb 19, 2007 | 08:23 PM
jayRS's Avatar
jayRS
sounds like the problem, when i spoke to him the other day he said he sorted it, i asked if he removed switch or cut wire, no, he too the insides of the switch out and put the shell of it back, dont ask me why
but it dont sound no more so he happy
Old Feb 20, 2007 | 04:22 PM
This is not the door switch but the GEAR LEVER ALARM!!
If you try to move gear lever with pressing button it will sound and should prevent you from being able to move lever until button is pressed, it is a lockout to prevent accidental engagement of gear, standard fitment.
ps the same buzzer does many functions such as lights as well
Ian1964
12
Jan 26, 2021 11:57 AM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
