A/F ratio
Well I hooked up a friends A/F gauge and at Idle it reads lean. It only has leds to tell you so I don't know the actual measurement. Also when we hook it up it doesn't always read. Could my O2 sensor be going bad?
PassionFords Creator
Could well be.
As long as its idling, it doesnt really matter how lean you go as long as you dont induce a missfire from entering the 15:1 zone TBH
Originally Posted by Jim Galbally
here's a Q... what voltage/resistance/whatever should a lambda/hego read at lambda 1?
just need to check mine at idle, n only got a multimeter, not a gauge
to measure it you would need a multimeter with a high input impedance (so no moving coil meters)
S1
Jul 9, 2004 06:36 AM
