Correct geo. settings
Old Feb 10, 2007 | 08:51 PM
iansoutham's Avatar
iansoutham
OCD Victim
Default Correct geo. settings
Does anyone know what the correct / best front toe settings should be for a 4be Saff (TwinCam non-Cossie) with poly front bushes (I know it should make no difference, but...)?
It has always "scuffed" on the road surface on full-lock, forwards and backwards as if the wheels are slipping when manouvering. Back it off a 1/4 turn and it is fine. It is currently set @ static parallel. I will be lowering it @ some point from standard 4wd Cossie height springs to -25mm, so will be wanting to set it up again @ that time. I will also be shimming the rear-end @ the same time back to standard specs, if that helps.
Old Feb 11, 2007 | 07:09 AM
I think you will find they will all do this on full lock, mine does, set parrallel.
Old Feb 11, 2007 | 08:52 AM
iansoutham's Avatar
iansoutham
OCD Victim
You can change it so it does not though. Mine never used to when I was running lousy Continental tyres, only once I changed to the Bridgestone S-02. I believe Mike or someone similar has the specs or would know what they should be.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
RSmark84
Sep 13, 2015 01:29 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
