New production side skirt clips
Hi! As Ford no longer supplies the clips for the side skirts i am looking on making a new production of them. I,ve got a friend who is able to make them. we are also looking at different plastics to increase the durability of them, as tha standard ones are crap. Is there any intrest of these in UK for your cossies?
Cheers!
Johnny Lehti.
Cheers!
Johnny Lehti.
I bought originals and 3/4 of them broke, even though i filed them to ease the fit. Well pissed off coz they cost a fortune.
Metal ones with rubber inserts would be perfect.
I bent a few pieces of aluminium and screwed them diectly into the sill lip.
I made some metal side skirt clips, I bent them to the shape of the plastic ones and used silicone to attach them to the sills.
All that it cost was the price of a pair of cheap tin snips and the metal was bent in my vice.
Okay, seems like there is a big interest in those parts! I see if i can have the parts for the bumper made aswell. I just need a set to copy, but we have some parts in stock! I,ll be back!
Hi! we have made a prototype in Aluminium which is mounted with two small screws that clamp on the car, and a hole in it where you attach the sideskirt with a small screw instead of a rivet. Much easier to remove. I get back with prices for a complete set when i know the production cost for them. These will not break!
Johnny.
Johnny.
Originally Posted by Nash
Has anyone tried dropping the Clips into hot water before fitting to stop them snapping?
My mate who works at Ford did this when restoring his Saph and said it stopped them snapping.
they just go brittle again when cool though, so still snap at the slightest impact
i wouldn't want to be screwing aluminium to the steel sills, it's asking for corrosion problems
If I remember correctly, aluminium is the sacrificial material when in contact with steel, I am sure if you use steel rivets on aluminium panels it is the panel that corrodes around the rivet and the panel then falls off, should be fine though if the steel is painted as it will stop the reaction, I am only about 70% sure of this though as been a long time since I was at college.
Johnny.
Johnny.
So even with a crusty sill u can still fit um
Yeah, the side skirts are held on by plastic brackets that rivet to the skirt and push onto the sill.
I have the same problem with mine, i've had 2 sets of them but the plastic is really brittle and they break so easily!
THey should still be available from fords though.
Originally Posted by hitchwest
does anyone know what holds the front part of the saff sideskirt the bit with the jacking cover in as the back end of mine sticks out is there a clip to hold it to the sill
thats why mine is bent because i bent one of the rivits that hold in in place pushing the fooker on
it's about 3 inches long and has 3 holes in it
