cossie managemant parts needed
if youre using a fiesta cvh block, can u use the efi crank/flywheel sensorinstead of a trigger wheel...??? and can u run cos management with the fiesta coil pack seein as it fits so nicely on the end of the head..!!??
Originally Posted by mitchrst
i have mate jano wants about Ł2100 tho thats why im trying to find how to do it myself if i can
Marelli management is bizzare, and needs a 4 tooth pickup wheel. You could modify the flywheel for this, but it's easier to mod a crank pulley. The fiesta efi system is capable of providing much more accurate timing information with its 36-1 wheels.
Marelli also has only one spark output, so needs an ancient dizzy. Stu does a board that allows you to drive a modern coil pack, defo worth while if u are going to the trouble of marelli.
155lee
Sep 14, 2015 07:37 PM
kosienutter
31
Aug 22, 2015 09:55 AM
155lee
Aug 14, 2015 11:21 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
