What map sensor please
Old Feb 4, 2007 | 10:57 AM
xrt-mart's Avatar
xrt-mart
Default What map sensor please
What map sensor do I use for my OFAB ecu if I wanted to run a stage 2 chip and different injectors? running say 14-15 psi for example, 2.5 or 3.0 bar
cheers
mart
Old Feb 4, 2007 | 11:20 AM
daveselwood's Avatar
daveselwood
3 bar
Old Feb 4, 2007 | 01:51 PM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by daveselwood
3 bar
Its normally a 2bar. Fitting a 3 bar would melt teh engine on one mapped for a 2bar.
Ultimately, only the mapper of the chip will be able to tell you. However, all good chips come with full fitting instructions anyway. have you read them?
Old Feb 4, 2007 | 02:59 PM
xrt-mart's Avatar
xrt-mart
OK then what would you recommend as a package? I Have my engine being built at the moment. It is a 2.1 ZT fitted with arias pistons (7.4:1 C/R) on std rods.
I was hoping to run it on 2 bar, but at the moment i am stuck on chip needed, injector spec (using endfeed injectors) and what sort of map sensor I need to match the lot up.
any advice accepted
cheers
mart
Old Feb 4, 2007 | 07:00 PM
Your ONLY acceptable and safe option is a full live map on that spec with OFAB mate.
Old Feb 5, 2007 | 05:01 PM
SafeChav's Avatar
SafeChav
3 bar
Its normally a 2bar. Fitting a 3 bar would melt the engine on one mapped for a 3bar.
Stu........tell me to shut up if im wrong but surely you mean fitting a 3 bar on a car mapped for 2 bar (or vice versa)would melt the engine.
Old Feb 5, 2007 | 05:10 PM
3 bar
Yes mate... Im a moron and have edited appropriately... lol
Old Feb 5, 2007 | 05:14 PM
SafeChav's Avatar
SafeChav
Well i did wonder whether to question it incase i looked silly
Ah well
Old Feb 9, 2007 | 07:42 PM
Old Feb 11, 2007 | 05:43 PM
SafeChav's Avatar
SafeChav
I should really start copying/pasting some of those owned pictures
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
