Removing Exhaust Manifold
Old Feb 3, 2007 | 05:57 PM
Brian's Avatar
Brian
Default Removing Exhaust Manifold
I need to replace the exhaust gasket (exhaust manifold to head)on the Series 2 as its blowing.
whats the best way to remove the manifold?? With the turbo still attached to it or am i better off removing the turbo from the manifold??
What else should i look out??
Anyone got any tip's??
Brian
Old Feb 3, 2007 | 06:04 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
If it weren't for the middle stud that is a pain, you could remove the studs (using an inverted Torx bit) and replace the gasket with everything else in situ, however the middle stud normally won't come out as it is a locator. I have modified that stud on mine, so that I can remove the studs easily.
Old Feb 3, 2007 | 07:03 PM
steven botes's Avatar
steven botes
from my experience , the only way to ensure a good seal and still save your hands is to remove the fan ,then the rad and work through the front sitting on your arse.
i have replaced the std rad fan with a 12"flat one so the rad comes out without having to remove the fan
Old Feb 3, 2007 | 07:43 PM
SafeChav's Avatar
SafeChav
I don't follow you there Christian? Whats special about the middle stud?
Old Feb 3, 2007 | 07:57 PM
Christian and Beccy
#1 in Spelling Club
OK, I knew I would get asked this!!
On a Standard RST exhaust manifold, there is a single stud-hole in the middle which is smaller than the rest. Also, the studs themselves have a small shoulder which means that the stud won't pass completely through the smaller hole.
It was done to be a tight fit to locate the manifold correctly. Having weighed up the pro's and con's, I filed the shoulder on the stud down as it makes it so much easier to remove!! I guess alot of RST's have had this done in the past too.
Make sense?
Old Feb 3, 2007 | 08:05 PM
SafeChav's Avatar
SafeChav
Make sense?
I wasn't even aware of that mate so thats why it made no sense to me
looks like all the ones ive ever had have been modified/worn then lol, cos as im sure you know most of the studs usually come out with the nuts lol
Old Feb 3, 2007 | 08:07 PM
SafeChav's Avatar
SafeChav
Lol if you knew why didn't you say
Old Feb 3, 2007 | 08:38 PM
Christian and Beccy
#1 in Spelling Club
'Cos it was tough to explain!!
Old Feb 3, 2007 | 10:43 PM
SafeChav's Avatar
SafeChav
Awww diddums
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
jamie956
21
Sep 16, 2015 06:24 PM
grishenko45
Sep 9, 2015 12:58 PM
hopper350
Sep 4, 2015 12:53 AM
