revs cut out to soon?
Grey Mk4 Early XR3I
ive just recently been thinking my revs are cutting out way to early cutting out between 5 and 5n a half thousand ive been told in my dizzy theres a "spark cut out" or somthing i was wondering is there any way to get around this? as the car seem to still be pulling and gaining quite well so i assume the rev limiter is around 6.5 k? how can i get the car to have them extra few revs?
my rs revs to 6500 before rufusing to go no further,
rs turbos have a 2 stage rev limeter, the first stage cuts in at 6200, the second at 6500
perhaos your rev counter is wrong, most are
How do u get urs to rev to 6500? lol
A standard car will cut at about 6200, which is an ignition cut. The fuel cuts later, this is normal.
The same symptoms of early rev-limiter hitting is often seen with certain aftermarket cams/springs.
TPM961
Jan 15, 2018 10:50 AM
Mark RS
Oct 12, 2015 06:01 AM
