Brake bias box
Old Feb 1, 2007 | 05:16 PM
mk4gartrac's Avatar
mk4gartrac
Default Brake bias box
Has anyong got any pics of a universal or cosworth brake bias box as im looking to change my master cylinder to a bias setup but due to my car being part sierra and a mk 4 escort im not sure what will fit or how they fit any help would be great thanks
Old Feb 1, 2007 | 09:14 PM
NUTS RuS's Avatar
NUTS RuS
Im just in the middle of converting a sierra one for someone at the minute. Will post a pic once done
Old Feb 2, 2007 | 08:48 PM
mk4gartrac's Avatar
mk4gartrac
ok thanks.
dose anyong know of anywhere that sells universal brake bias boxes?
Old Feb 3, 2007 | 10:05 PM
Wardy257's Avatar
Wardy257
www.obp.uk.net
Old Feb 4, 2007 | 12:54 AM
NUTS RuS's Avatar
NUTS RuS
Pics as promised.
Standard Sierra pedal box supplied to us for modding/conversion to bias box. All other components supplied with it but not photographed. IE Master Cylinders, Fixing Kit etc.
Thanks
Tony
Old Feb 16, 2007 | 10:08 PM
robrs2's Avatar
robrs2
Just the pics i was after. are the master cylinders on the other side of the bulkhead?
Old Feb 17, 2007 | 08:02 AM
mk4gartrac's Avatar
mk4gartrac
Thanks looks good .Ive managed to fit a universal bias box in the engine bay rite behind the pedels it isnt quit finished but ill post some pics when im done
Old Feb 17, 2007 | 08:06 AM
mk4gartrac's Avatar
mk4gartrac
When i run the brake lines can i go strait to the calipers with them or would i need to put any sort of valves in befor them???
Old Feb 17, 2007 | 11:35 AM
robrs2's Avatar
robrs2
You should be able to run stright to the calipers. Rear discs some time cause a problem with knock off. Mostly on fwd cars. This is when the disc knocks the pads back. All discs knock the pads back to a small degree but doesn't cause a problem.
If the pedal goes soft after cornering the car then you may need to for a pressure retaining valve in the line.
Old Feb 17, 2007 | 11:46 AM
mk4gartrac's Avatar
mk4gartrac
Thats what i thought ill see what its like once all fitted if need be ill fit 1 after.Thanks for that
yatta
May 21, 2016 10:31 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
