willl a blue red blue ecu work in a 90 spec car?
so basically straight swap..? ihad my car up to get a chip fitted it was hearts and diamond with a wtb or wot ever mod it's called the car was over boosting like hell when the mechanic opened it up he pointed out a adjustment screw inside the ecu wot is this for safe chav?
Yea just plug it straight in. What you have there is a Series 1 ECU, they are supposed to be the better ones as they don't have the knock sensor which can cause ignition retard.
Exactly the same wiring configuration so plug it in and get it set up
As for the screw mate that sounds well dodgy as i said on the other thread, get a picture up
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
