Springs and Shocks
I need to replace the front shocks on my S2. I won't be doing this until next month as I've just spent all my money for this month on a paddle clutch.
What do you guys recommend. I'm not sure I can stretch to £600 for pukka coilovers, looking more to springs and shocks.
Car is currently decked, and I mean decked. The fronts are virtually tucked under the arches (cannot get finger between arch and tyre) with 205/40/17's.
I want to keep the 17's as I'm planning big brakes, but want to raise the ride height a bit, say 15 mm, and soften the ride as it is currently teeth shattering. I'm not after standard ride height, just a bit higher than now and slightly more cushioning than basically solid!
I realise I will not be able to just launch it into corners as hard, but it's getting annoying crawling over speed bumps in 1st.
Any help at all?
Any help at all?
SMILER258
Sep 28, 2015 09:04 AM
