BADLY SMOKING S1
Old Jan 31, 2007 | 04:53 PM
dazoriginal's Avatar
dazoriginal
prodigal son
Default BADLY SMOKING S1
HI ALL ANY HELP I HAVE A TRANSPLANTED XR2 MK2 USING THE S1 ENGINE IT SMOKES VERY BADLY, COLD AND ,HOT SOME CLEAR SMOKE ,SOME BLACK AND IT STINKS WHAT COULD IT BE
THANKS
Old Jan 31, 2007 | 05:56 PM
nick series1's Avatar
nick series1
Clear smoke will be water - White smoke
Head gasket ??
Black smoke would indicate that it is overfueling.
Sensor - cold start valve ??
Old Jan 31, 2007 | 08:11 PM
SafeChav's Avatar
SafeChav
You sure the majority of it isn't just steam? Big exhuasts create a lot of steam in this cold weather.
If the engine is unknown to you do a compression test as a starting point
Old Jan 31, 2007 | 10:26 PM
khanny's Avatar
khanny
Ye defo do a compresion test i thougt my turbo was fooked and bought a new 1 turned out to be engine problem defo do it m8 it will save you a fortune
Old Jan 31, 2007 | 11:18 PM
dazoriginal
prodigal son
will do a comp test see how that goes every little helps thanks
Old Jan 31, 2007 | 11:23 PM
SafeChav's Avatar
SafeChav
Its a good starting point and your not throwing money away
Keep us posted
Old Feb 1, 2007 | 12:09 AM
rst_cabby's Avatar
rst_cabby
Agreed with Safechav do a compression test first ......
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Fordmad!
Sep 29, 2015 07:03 PM
