s2 - hot hot hot
Old Jan 30, 2007 | 09:07 PM
StuRST's Avatar
StuRST
Default s2 - hot hot hot
a friends s2 is having serious overheating probs, we cant work out why, even with both kenlowes on it still gets right up near the red and the water in the header tank bubbles like mad, when the cap is taken off shit loads of air comes out
things we have changed so far;
rad
thermostat
coolant hoses
header tank
pressure cap
Y peice (that goes into the heater matrix) - had a small split in it
while running cool the car drives spot on, but boils up very very quickly... there isnt any sludge in the header tank or in the rocker cover - so the head gasket should be fine?
there doesnt seem to be any water leaks from anywhere either
any ideas???
Old Jan 30, 2007 | 09:28 PM
SafeChav's Avatar
SafeChav
Have you got the fans wired in the the right way.........
Old Jan 30, 2007 | 09:42 PM
nick series1's Avatar
nick series1
Things i'd check would be:
As above - Fans are sucking in cold air from the front of the car
Is the water pump actually circulating the water
Or are the pipes DEFINATELY plumbed in correctly
Failing that - i have known that the timing being severely out causing this type of overheating.
Have you done anything to the car before this happened (ie put on a silicone hose ket) or did it just happen one day.
Old Jan 30, 2007 | 09:58 PM
gup's Avatar
gup
poss air lock or headgasket can go between the bores
Old Feb 13, 2007 | 05:10 PM
StuRST's Avatar
StuRST
we checked the fans and they were blowing air through the rad - so fine
then we went onto change the head gasket which when we took it off definately looked like it needed changing
but now we cant get it to fire up, it spins over fine, every now and then while spinning over you get a faint pop from the exhaust
while taking the head off somehow theyellow connector plug managed to get caught between the head andthe block snapping some of it so for the time being we have just used connectors - btw what does the yellow one control???
timing has been checked and is fine
petrol is fine
anything else that could bestopping it starting???
Old Feb 13, 2007 | 06:08 PM
SafeChav's Avatar
SafeChav
The yellow plug is absolutely crucial - its the main engine temperature sensor.
You've got the HT leads on in the wrong order i expect if its back firing!
Old Feb 14, 2007 | 04:48 PM
rowen20's Avatar
rowen20
also check the water pump fins as the last couple of rs's i've had have both needed water pumps due to the fins corroding off....
Old Feb 14, 2007 | 06:31 PM
SafeChav's Avatar
SafeChav
Just a thought aswell,have you got the wires from the yellow plug sandwiched in with the headgasket?
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
