Brake adjustment
hello just wandering if anyone can help i'v just lowered my escort and i know i need to adjust the rear brakes to compensat the car being lowered just wandering how to do it.i'v seen what needs adjusting i just don't no how to do it
Originally Posted by Alex_86
u need to adjust you rear breaks, when u lowered it? new for me that one....
Im not too sure whats involved mate, obviously yes you have to reset them to compensate but its not something ive ever looked into.
Would be best to have the brakes checked on rollers after aswell to check they are balanced.
Originally Posted by rs shawn
I don't think Mk4s have a proportioning valve fitted. Never did it on mine after lowering.
everything else is fixed rate under the bonnet
They aren't inline on them, the bolt up to the central wishbone mount under car and have arms attached to the wishbones.
As i said its probably not essential but lowering the car will increase the braking on the rear meaning it could get a bit arse happy
I'll get a picture now!
SafeChav Given up ! No fookin stamina on these kids today
I've found the thread and all the pics are now gone
So I've pm'd Adam asking to upload a pic again & directed him to this thread
Originally Posted by daveselwood
i thought they were only on vans
What type of suspension do the vans have though.........yes........leaf springs
Found it..it's apportioning. My bad
Some info on a ford site..but not sure which ford.
http://209.85.129.104/search?q=cache...n&ct=clnk&cd=5
Basically all it does is shut off the flow of brake fluid to the rear brakes. The adjustment is critical to prevent the back brakes from locking up! If the car has been lowered then the amount or rear end lift will be greater to get the valve to operate, by this time the rear wheels will probably be off the ground and the rear wheels will be locked!
In the above pic the adjustment arm on the left hand side would be rotated anti clockwise (viewed from the rear) when the vehicle had been lowered. The right hand side adjustment arm would be rotated clockwise.
