What affects would you get if exhaust valves not seating????
Old Jan 30, 2007 | 07:23 PM
lawnsy's Avatar
lawnsy
Default What affects would you get if exhaust valves not seating????
Just stripped my cossie head down to fit new valve stem oil seals and noticed that about 4-5 exhaust valves have not been seating propperly and are thick of carbon.
What affects would i have got off this as i thought the car was running mint before i stripped it.....?
Old Jan 30, 2007 | 09:02 PM
James's Avatar
James
errrrr, they're supposed to be like that?
as the exhuast valves open the exhaust gasses go around the valve over the back of the valve into the port and into the mannifold leaving carbon deposits as it goes.
Old Jan 30, 2007 | 09:05 PM
lawnsy's Avatar
lawnsy
no i mean balls of carbon you can see they not shutting fully..
Old Jan 30, 2007 | 09:07 PM
xr-stu's Avatar
xr-stu
Default Re: What affects would you get if exhaust valves not seating
a wise man once said "if it aint broke, dont fix it"
Old Jan 30, 2007 | 09:11 PM
lawnsy's Avatar
lawnsy
lol the head gasket went at croft.......so decided to rebuild it as oil perssure was a bit low anyhow. so now had reground crank, new mains, bigends, thrust's, rings, honed bore, stud n nut kit, cometic head gasket, oil pump, everygasket new,
and now i starting on head....
Old Jan 30, 2007 | 09:18 PM
AlexF's Avatar
AlexF
low performance!!!
So grind (lap) the valves back in and change the stem seals will your at it
Old Jan 30, 2007 | 09:20 PM
bud-weis's Avatar
bud-weis
Football Cwazy
a good possibility that if left,the valves would burn out!!!
the valve seat conducts a lot of the heat from the valve..
a basic no frills head rebuild at NMS is pretty damn cheap IMO,worth having done properly
Old Jan 30, 2007 | 09:21 PM
lawnsy's Avatar
lawnsy
funny thing was it seemed to run ok but when it came on boost it never felt like it had the kick it used to .......
i going to lap the valves in tomorrow and i got the valve seals to go in...
Old Jan 30, 2007 | 09:23 PM
lawnsy's Avatar
lawnsy
by the look of it the guide's have not long been done and it looks like it has had new valve seats....
AlexF's Avatar
AlexF
good man!
Its worth spending time on and really doing a top job - the exh valves will probably be very pitted and require lots of work!
Alex
Old Jan 30, 2007 | 09:32 PM
James's Avatar
James
ahhhhhhh i'm with you now!
Old Jan 30, 2007 | 09:33 PM
lawnsy's Avatar
lawnsy
yip that the bit i dreading.....
TPM961
Jan 15, 2018 10:50 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
