XR4i dampers -v- 2wd Cossie dampers
Old Jan 30, 2007 | 10:54 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default XR4i dampers -v- 2wd Cossie dampers
Does anyone know if the spring cup dimensions are the same, as in would a set of springs designed for a Cosworth be the correct length and therefore height, or would they need to be longer / shorter?
Old Jan 30, 2007 | 11:02 AM
dojj's Avatar
dojj
Resident Wrestling Legend
they will fit, but the spring rates are different due to the wieghts of the engines
i think that the cossie springs are rated higher but are shorter while the 4i springs are ongers but softer
does that makes sense?
Old Jan 30, 2007 | 11:06 AM
dojj's Avatar
dojj
that should say "longer but softer"
Old Jan 30, 2007 | 11:09 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
are you refering to standard springs mike
Old Jan 30, 2007 | 11:17 AM
Mike Rainbird
Caraholic
I just wanted to know what effect fitting springs designed for a Cosworth would have being fitted to an XR4i? They are fractionally lower than normal at 15mm on the front.
As in, would they be too short or would they sit okay?
Old Jan 30, 2007 | 11:20 AM
...oh so you bought that XR4i then Mike
..oh and yes i accept your offer for my neons...your little girl is gonna think your the coolest dad around
Old Jan 30, 2007 | 11:44 AM
dojj's Avatar
dojj
the spring rate for the cossie is (from memory) 140lb/in and the one for the 4i is (again, from memory) 105lb/in
but the cossie spring is shorter so that it won't compress as much
the 4i spring is longer but softer so it will compress more but it should be the same ride height
as someone who knows a tad more than me about what this will do you'll probably find that the cossie springs will firm up the ride in the 4i but it may sit a bit lower than normal overall
Old Jan 30, 2007 | 11:46 AM
Mike Rainbird
Caraholic
One car has a Cossie lump fitted and the other a V8 . I just don't want the cars to sit too low and for the springs to be overworking the dampers by being possibly too short .
I was hoping that you would say the actual damper lengths that the sprongs sit in are identical , that would make me VERY happy .
Many thanks for taking the time to post .
Old Jan 30, 2007 | 12:09 PM
cossie4is dad's Avatar
cossie4is dad
I changed all my 4i suspension over to a Koni kit for a Cosworth.
So i cant help
What you doing with the 4is Mike ?
Steve.
Old Jan 30, 2007 | 12:11 PM
MWF's Avatar
MWF
They aren't both black and on 7 spokes are they?
Old Jan 30, 2007 | 12:13 PM
Mike Rainbird
Caraholic
So i cant help
Steve.
Trying to help get the cars to handle (it's Pete and Mark ). This maybe the way to go if the height isn't right .
Old Jan 30, 2007 | 12:14 PM
Mike Rainbird
Caraholic
I've only seen pictures of one (Doh AKA Pete's).
Old Jan 30, 2007 | 12:15 PM
cossie4is dad
So i cant help
Steve.
Any tips would be good
Mine has standard cossie ride height springs, poly bushes and a cossie front ARB.
Steve.
Old Jan 30, 2007 | 12:17 PM
Turbosystems
Super Moderator
here's a tip buy an evo
Old Jan 30, 2007 | 12:24 PM
dojj's Avatar
dojj
as far as i am aware the rest of the strut is identical (but very spindly looking comapred to the 4wd stuff i normally see )
the 4wd springs are margianly different again to the 2wd cars but i'm not sure how much sfitter they wuld be as they have to support the extra weight
which V8 is it under the bonnet? if it's a rover they tend to be the same sort of wieght as the cossie anyway but if it's one of the other forign imports then it's a case of trial and eror
Old Jan 30, 2007 | 12:28 PM
MWF's Avatar
MWF
It's a Ford Smallblock 302 I think
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
