More torque....????
Old Jan 29, 2007 | 09:16 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default More torque....????
i know that bhp is worked out by measuring the pull on the rollers/dyno and revs...but how do u get a higher torque engine...mine is 420bhp/370ftlbs....how do u produce more than ur bhp figure....cheers Pete
Old Jan 29, 2007 | 09:18 PM
radiant red's Avatar
radiant red
nitrous??
_DAN_'s Avatar
_DAN_
Yoon
You can't because of the 5252rpm thing isn't it?
On a similar note,in this months PPC.Dave reckons ATW (at the wheels) is rubbish,but gives no reason for it being so.
Any thoughts on ATW people?
radiant red
larger capacity with less boost??oh ill shut up and leave it to the experts lol
Old Jan 29, 2007 | 09:20 PM
_DAN_'s Avatar
_DAN_
Yoon
But wouldn't that just offset it?
I thought torque was a product of boost,summant to do with PCP's?
I'm probably wrong.
Old Jan 29, 2007 | 09:21 PM
bud-weis's Avatar
bud-weis
Football Cwazy
easiest thing is more BOOOOSST!!!!!! or at least a huge boost spike to give you an almighty shove
how much boost do you run?
mine made 390lb/ft with a spike of 2.1bar....boost dropped quickly after though....
Old Jan 29, 2007 | 09:22 PM
pete mcrash
u see cars with more ftlbs than bhp....just wondered how
rapidcossie's Avatar
rapidcossie
what would ATW figures be rubbish?
as these are the figures actually produced and not some calculation done by the rolling road?
GARETH T's Avatar
GARETH T
set your rev limiter to 5252 RPM
Old Jan 29, 2007 | 09:23 PM
pete mcrash
....hits 30psi then holds 27/28psi
Old Jan 29, 2007 | 09:24 PM
big_wig_074's Avatar
big_wig_074
about 2.5 bar spike ought to bring the torque RIGHT up in the mid range!
Old Jan 29, 2007 | 09:25 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
boooooooooooooooooooooost is the biggest thing to increase torque by miles.
nothing makes a difference even close
Old Jan 29, 2007 | 09:26 PM
Rhys's Avatar
Rhys
Thats cheating!
Lots of different ways to make a car produce more torque, there is no one simple method
bud-weis's Avatar
bud-weis
Football Cwazy
the easiest thing to do,without changing spec is to have a remap,but ask for a large'ish boost spike that can maybe be held for a little while,but then tailing it slowly as the revs build,so the injectors don't get maxed too much......i presume you are on greys?
Old Jan 29, 2007 | 09:28 PM
pete mcrash
i thought it was a maths equasion so much torque = so much bhp...
Old Jan 29, 2007 | 09:29 PM
radiant red
the gunship map has a big midrange boost spike doesnt it??
pete mcrash
...no fella light blues...cant run more boost safely
Old Jan 29, 2007 | 09:31 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
fuck off big boost spike
Old Jan 29, 2007 | 09:35 PM
big_wig_074
greys,remap,big spike = big torque!
oh and you can sell the blues to recoup some losses (i never did understand why theyre more expensive than greys! )
bud-weis's Avatar
bud-weis
Football Cwazy
there is a calculation;
Power [bhp] = Torque [lb-ft] x Speed [1/min] / 5252
i'd say your pretty much at the limit of your spec then lol.....you could squeeze more out by having the above 'adjustments'
Old Jan 29, 2007 | 09:38 PM
pete mcrash
dont think remap would matter im on a standard head so wouldn't flow anymore air...its just for the future....
Old Jan 29, 2007 | 09:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Thats cheating!
yeah there is.
boost.
by far the best by a huge margin
Old Jan 29, 2007 | 09:47 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i'm thinking about organising another RR day actually.....i've found a rollers which i beleive to be very good,certainly the best and most accurate i've been on to date (they seem accurate from the readings i and a few others got)
long way for you to come though,but you never seemed happy with the well lane RR
Old Jan 29, 2007 | 09:52 PM
pete mcrash
wasn't not happy....but it didn't make full boost on the rollers and the power graph/info was shite....and on my spec im not suppose to have this much power...even though standard cars made standard power that day aswell.....how far is ur RR
Old Jan 29, 2007 | 09:55 PM
bud-weis's Avatar
bud-weis
Football Cwazy
well it's in a place called Solihull.......have a look on AA,i bet it's a fair drive?
Old Jan 29, 2007 | 10:03 PM
pete mcrash
tis a ride out....2:30-3hrs....i 'll wait till warmer weather when i can turn it back up and have a higher spike again....
Old Jan 29, 2007 | 10:45 PM
89xr2's Avatar
89xr2
Brap!
Why do modern WRC car's make so much torque compared to bhp?
Old Jan 29, 2007 | 10:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
booooooooooooooooost
and they restricted so cant rev high so bhp never gonna be that big.
Old Jan 29, 2007 | 10:59 PM
89xr2's Avatar
89xr2
Brap!
What sort of boost pressure do they run? And how does that compare to say an average 500 bhp cossie?
Old Jan 29, 2007 | 11:05 PM
bud-weis's Avatar
bud-weis
Football Cwazy
uncomparable to a 500bhp cossie really, well most 500bhp cossies that is..WRC cars run huge boost through relatively small turbos (they have restricters fitted which ulitimately limits BHP)
500bhp cossies are usually Low Comp with large Turbos running maybe 2.5bar held
not entirely sure what boost WRC cars run,but i guess it's pretty high (40+psi) also they are much higher comp
Old Jan 29, 2007 | 11:11 PM
Staffi's Avatar
Staffi
Weston Performance.................
Old Jan 29, 2007 | 11:15 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah you know it? very impressive setup....although i don't know if the workforce are clued up or not.....but they seemed ok to me,apart from all of the japscrap lying around
Old Jan 29, 2007 | 11:20 PM
Staffi's Avatar
Staffi
yeah, good setup though mate i think?
If you`re organising a RR Day there, let me know mate...
Old Jan 29, 2007 | 11:24 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yep,they have a well sorted setup IMO......just thinking about it at the mo,but unlike the last one i'd need deposits/payment in advance....just to get definites i'll let you know if i do
Old Jan 29, 2007 | 11:26 PM
Staffi's Avatar
Staffi
Good man and deposits is a GOOD idea after the last disaster
Old Jan 30, 2007 | 05:56 AM
pete mcrash
i like Stavros....everything in the world can be sorted with MORE BOOOSTT.... COME ON...!!!!
Old Jan 30, 2007 | 07:38 AM
CossieRich's Avatar
CossieRich
big boost rules and breaks things
Old Jan 30, 2007 | 04:35 PM
pete mcrash
....Mmm gearboxes...
Old Jan 30, 2007 | 04:38 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Theyre diesels most of em
Old Jan 30, 2007 | 04:53 PM
Mark Shead's Avatar
Mark Shead
Western performance have a Dyno Dynamic RR, I have just run on Surrey RR one with a Escort Cos making 394hp and 390ftlb at the wheels which worked out with the Subaru trans losses 504hp and 490ftlb at the fly which is very close to what these engines make on the engine dyno
Mark
