Muppet time petrol pump querry!! (Pic request)
Old Jan 29, 2007 | 03:27 PM
Dumpy's Avatar
Dumpy
Default Muppet time petrol pump querry!! (Pic request)
Hello all,
Bassically my fuel gage isn't working - but the car is still running fine!!
My guess is that the fuel pump connections have broken/corroded on the actual pump!! Now here is the question - can someone please tell me where my fuel pump is (a pic would be good) and which terminals each colour wire goes to please??
Hope it is this otherwise my dash is coming apart
Cheers,
Dumpy
Should also ask it is a S1 engine in a S2 shell!!
Old Jan 29, 2007 | 03:32 PM
antony215's Avatar
antony215
Escort Rs Turbo
The fuel gauge has nothing to do with the pump if your gauge aint working then it's either the gauge in the dash is fucked or the sender in the tank
Old Jan 29, 2007 | 03:36 PM
Dumpy's Avatar
Dumpy
Damn more of an issue than i thought!!
Cheers for that i shall have to look for the connections on the fuel tank then - where will the wires be on this??
FFS!!
Cheers,
Dumpy
Old Jan 29, 2007 | 03:38 PM
antony215's Avatar
antony215
Escort Rs Turbo
Id try changing the gauge in the dash first mate because if the sender is gone then that means you need to drop the tank
Old Jan 29, 2007 | 03:45 PM
Dumpy's Avatar
Dumpy
Cheers Buddy - looks like i'm a bit fooked really as M.O.T is due next month!!
Smeg!!
Cheers,
Dumpy
Old Jan 29, 2007 | 04:15 PM
Dumpy's Avatar
Dumpy
Here's another question - i'm sure i saw a picture of an engine that arrows to the parts of the engine and what they were - does any one know where this is or seen it??
Cheers,
Dumpy
Old Jan 29, 2007 | 04:20 PM
Moonie's Avatar
Moonie
Smeg!!
Cheers,
Dumpy
Whats the fuel gauge go to do with the MOT?
Old Jan 29, 2007 | 04:27 PM
Dumpy's Avatar
Dumpy
Suerly if it is showing empty when the tester is in the car and still running it will show some cause for concern - hopefully i am wrong!!
I thought that if it shows below the limit it would fail!!
I hope i am wrong on this however!!
Cheers,
Dumpy
Old Jan 29, 2007 | 04:47 PM
SafeChav's Avatar
SafeChav
OMG this has gotten very messy already!
Back to basics..........is your car an MFI RST firstly......
Old Jan 29, 2007 | 05:00 PM
Dumpy's Avatar
Dumpy
I beleive so - i do appologise SafeChav, never owned a turbo or anything with any power really, so if i get a photo of the engine would somebody please tell me where the locations of some parts of the engine are and wheteher it is MFI or EFi!!
Sorry for my thickness/inexperience!!
Cheers,
Dumpy
Old Jan 29, 2007 | 05:16 PM
fast_ford_uk's Avatar
fast_ford_uk
the fuel gauge is not an mot failure
davsmith64's Avatar
davsmith64
ok look at your engine bay.. does it have a distributer? also at the right hand side of the bay does in have a metering head with red pipes coming from it to the inlet manifold..i.e. injectors
Old Jan 29, 2007 | 05:25 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Easiest way to tell on the engine is if it has a big EFI stamped onto the big metal bit at the top of the engine as you look at it.
Old Jan 29, 2007 | 05:30 PM
SafeChav's Avatar
SafeChav
Dumpy no need to appologise mate, i just meant it was getting a bit outor proportion for something that is more than likely an easy fix
Now.....if you pull the rear seat bench forward, i THINK there is a multiplug just before the loom goes through the grommet in the bodywork.
Can you just have a quick look and see if there is before i carry on
Well durrrrrrrrrrr
Old Jan 30, 2007 | 08:45 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Well durrrrrrrrrrr
Shit off you..he said he didn't know and this to me is the easiest and quickest way
would somebody please tell me and wheteher it is MFI or EFi!!
<<< Have it.
Old Jan 30, 2007 | 12:32 PM
SafeChav's Avatar
SafeChav
Ave it, you slag
Old Jan 30, 2007 | 01:51 PM
Dumpy's Avatar
Dumpy
Sorry to interupt your flirting gents
I have taken the bench up took a photo on my phone and forgot my cable to get it on the PC
But looking at it there is a black plastic connector with a yellow and red wire into it!!
Looking at the engine i did not see any writting on it saying EFI but i have a photo here; i think MFI;
http://s93.photobucket.com/albums/l58/dumpy_01/rst/
Hopefully it will work!!
Cheers,
Dumpy
Old Jan 30, 2007 | 02:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
MFI my moneys on the sender being fucked
Old Jan 30, 2007 | 02:04 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
antony215 Agree..and agree
Live with it if you can Dumpy...unless the tank itself is rotten/rotting then replace both at the same time.
Old Jan 30, 2007 | 02:14 PM
Dumpy's Avatar
Dumpy
Whats the sender?? Only had the car a couple of weeks!!
Well pissed off - how easy / difficult is it to change one of these??
Cheers,
Dumpy
Old Jan 30, 2007 | 02:21 PM
antony215's Avatar
antony215
Escort Rs Turbo
The sender is a small float(more or less) that sit's inside the tank it send's a signal to the gauge to let you know how much fuel is in the tank. To get to the sender you need to drop the tank.
Old Jan 30, 2007 | 02:24 PM
Dumpy's Avatar
Dumpy
Cheers buddy,
Will see why safechav wanted me to check the wires under the bench!!
Cheers,
Dumpy
Old Jan 30, 2007 | 02:32 PM
antony215's Avatar
antony215
Escort Rs Turbo
yeah see what "THE PROFESSOR" has to say
Old Jan 30, 2007 | 02:37 PM
SafeChav's Avatar
SafeChav
To do probably the most basic and easiest test there is for a fuel gauge ANTONY
So is there a multiplug under there?
Old Jan 30, 2007 | 03:05 PM
Dumpy's Avatar
Dumpy
Looks like it - it is a black plastic connector with - see my paint drawing lol;
http://s93.photobucket.com/albums/l5...underbench.jpg
Orange bit is a plug - grey bit is a metal connector!!
Yellow wire looks like it loops but i cant remember wether it does or not!!
Sorry for being a muppet!!
Cheers,
Dumpy
Old Jan 30, 2007 | 03:09 PM
SafeChav's Avatar
SafeChav
Nah that surplus plug is for a fuel computer (thought the drawing was quite good actually )
Thinking about it i dont think the mk4's do have the plug being as the sender is top mounted.
What your locking for is a Brown/Black wire....can you see it?
Old Jan 30, 2007 | 03:10 PM
twinkle_2k86's Avatar
twinkle_2k86
come on savechav. use you eyes
Old Jan 30, 2007 | 03:16 PM
SafeChav's Avatar
SafeChav
Spot the deliberate mistake if i cant use my eyes numb nuts.
The reason i ask again is because he says theres a yellow wire under there?! Never will there be a yellow wire, if that plug is what i think, they will be Brown, and Brown/Red so ave that PROFESSOIR ANTONY
Old Jan 30, 2007 | 03:33 PM
Dumpy's Avatar
Dumpy
Sorry mate car is in my garage i'm at work so i will have to look and post pics with all my cables tomorrow!!
But these cables look pretty yellow and red on my phone - will take a few pics and see what i can find!!
I'm being proper stupid here but like i say i shall check it!!
Appreciate it gents!!
Dumpy
Old Jan 30, 2007 | 03:43 PM
antony215's Avatar
antony215
Escort Rs Turbo
SafeChav i know what plug your on about this one
Old Jan 30, 2007 | 04:09 PM
Dumpy's Avatar
Dumpy
The plastic thing is the same - but the wires are the diffent for sure i'll have to get a photo up!!
Cheers,
Dumpy
Old Jan 30, 2007 | 05:01 PM
SafeChav's Avatar
SafeChav
Appologies where its due, that wasn't even you that said that Antony
Damn you TwinkleTwinkleLittleStar
That is the plug though yes, and thats for a fuel computer. And no there isn't the plug i was hoping for
Basically the test you want to do, is bridge the Brown/Black wire to earth, and the gauge should read a full tank, if it does, the sender is probably gone, if not, its probably the gauge
Old Jan 30, 2007 | 06:12 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
See pic below for tank diagram
The sender is number 10/11/12 and has a float attached at the bottom which goes up & down with the fuel level. This movement is turned into an electrical signal..which is fed to your fuel gauge.
They are easy enough to change: but you have to remove the petrol tank as it fits into the top...hence why I said if you are happy to run with it like that then leave it unless your tank is rusty and needs replacing aswell. Do both jobs in one go to save messing around and labour costs. New tanks are around Ł60-70 ish. Senders guessing around the same: but not sure if you can buy new items: might have to be 2nd hand. If you do change the tank/sender, then get the brake lines checked along that side of the car: they run along the top of the tank and it's a tank-out job to replace them if they need doing. Get them done at the same time also
BUT
Ensure it is not an ELECTRICAL fault first..as Safechav is trying to establish..as you don't want to be changing the sender if it isn't faulty.
Old Jan 30, 2007 | 07:44 PM
SafeChav's Avatar
SafeChav
Sorry Shawn but that diagram was bugging me (you know what a fussy cunt i am)
Old Jan 30, 2007 | 11:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
SafeChav think you still need a pair of these
I know what other plug your on about (i think) sort of like the one above but it's for the fuel gauge. I couldn't see one on mine and i did feel under the carpet (as far as i could get my hand without taking the backseat/carpet out ) so you may be right they might not have them MFI anyway unless it's farther along the loom(but i wasn't going to take my back seat out to look ) or it may only be the EFI escorts as i swear my old XR3I and ORION (EFI) both had the plug you on about
Old Jan 31, 2007 | 11:19 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
SafeChav Fussy cunt
Have removed my pic, but left the description. Couldn't find the proper pic, so found one suitable-ish to explain it.
Was the description ok for you tho??
Old Jan 31, 2007 | 02:29 PM
SafeChav's Avatar
SafeChav
antony215 that was good of your mrs to let you post the picture up Say hi to her from Andy (Last weekend oh yeaaaaaaaa)
The plug i wasn't too sure about, i thought it might not have it being as the sender is top mounted, on the MK3's you can unplug it all and its a short loom, a nice feature IMO. Its been a while since ive had a MK4
rs shawn well now you mention it the description was a bit boring and long winded but i didnt want to hurt your feelings
Old Jan 31, 2007 | 03:46 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah i know what your on about it's got about 6-8 inch loom from the sender then theres the plug that plugs into the rest of the loom more or less the same sort of thing as the picture i posted im sure ive seen it on a mk 4 maybe the early ones
Old Jan 31, 2007 | 03:51 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
SafeChav Coont
Old Jan 31, 2007 | 04:26 PM
SafeChav's Avatar
SafeChav
That all depends on what you've been led to believe 6" is mate
SafeChav Coont
