bmw fuel pump-is this problem?
Old Jan 29, 2007 | 02:53 PM
Dragsteer's Avatar
Dragsteer
Default bmw fuel pump-is this problem?
Hello
I have fuel pump from bmw. I am sure that this bmw pump is weaker than original rs turbo pump.
Can I have problem with poor running because of this pump?
I can set up boost higher but car is not pulling good.
Maybe too low fuel prressure?
Old Jan 29, 2007 | 03:36 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Why would you want to use anything other than a Ford pump?
Old Jan 29, 2007 | 04:24 PM
That's what I thought, either way you need to check the fuel pressure under load as well as static.
Old Jan 29, 2007 | 07:53 PM
Dragsteer's Avatar
Dragsteer
Because ex owner do that. I will check pressure. Just want few opinions can weak pump be problem .thanks
muffster
13
Sep 3, 2015 09:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
