bmw fuel pump-is this problem?
Old 29-01-2007, 02:53 PM
Dragsteer
Dragsteer's Avatar
Default bmw fuel pump-is this problem?
Hello
I have fuel pump from bmw. I am sure that this bmw pump is weaker than original rs turbo pump.
Can I have problem with poor running because of this pump?
I can set up boost higher but car is not pulling good.
Maybe too low fuel prressure?
Old 29-01-2007, 03:36 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Why would you want to use anything other than a Ford pump?
Old 29-01-2007, 04:24 PM
That's what I thought, either way you need to check the fuel pressure under load as well as static.
Old 29-01-2007, 07:53 PM
Dragsteer
Dragsteer's Avatar
Because ex owner do that. I will check pressure. Just want few opinions can weak pump be problem .thanks
muffster
13
03-09-2015 09:40 PM
Sheepdisease
30-08-2015 09:11 PM
mickparky81
Ford Focus ST
30-08-2015 06:58 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
Quick Reply: bmw fuel pump-is this problem?
