Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Mk2 mondeo immobiliser problem
Old Jan 29, 2007 | 10:18 AM
adrianh's Avatar
adrianh
Default Mk2 mondeo immobiliser problem
Hi Folks,
I have a recurring problem with the immobiliser. It will activate first thing when trying to start and also whilst driving at random. I lose ignition and starter until it allows starting again usually after several turns of the ignition key from off to start. I've looked for the immobiliser where the Haynes manual states (Under the centre console) but its not there. Anyone any idea where it is hidden on the Mk2 Mondeo. Mine is a '97 model 5door.
Adrian
Old Jan 30, 2007 | 07:03 PM
djmillsy's Avatar
djmillsy
Fife Radge
have you got the red key
Old Feb 4, 2007 | 04:32 PM
adrianh's Avatar
adrianh
Hi,
I've placed a new thread in the technical help forum. It appears the immobiliser is up n under the drivers footwell. I will get it checked out when i get back home later. I do have all the keys, Red, red spot and remote.
Adrian
Old Feb 4, 2007 | 10:02 PM
djmillsy's Avatar
djmillsy
Fife Radge
i know you can reset the imobilizer with the red key
Old Feb 5, 2007 | 05:21 AM
adrianh's Avatar
adrianh
Would that mean it would automatically reset whilst driving, or is there a procedure to reset it once the car is stopped. I've a 125 mile journey to work and at the moment its cutting out once or twice each way. Turning the ignition off and on a couple of times seems to get it going most of the time, but on occasions i've been almost at a standstill or have to stop to restart the car again.
Just surprised that Fords haven't done a recall on these units as they are a positively dangerous system to have fail like this.
Regards
Adrian
Old Mar 8, 2007 | 06:25 PM
djmillsy's Avatar
djmillsy
Fife Radge
no when youve stopped it resets the whole car system
Old Mar 8, 2007 | 07:52 PM
robV6saloon's Avatar
robV6saloon
Go to www.fordmondeo.org and they will be able to help, I had the same problem and had mine removed because of all the problems i had.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Chopshop85
Sep 12, 2015 06:42 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
