saphy exhaust manifold 2wd or 4wd
Old Jan 27, 2007 | 07:08 PM
need4speed00001's Avatar
need4speed00001
Default saphy exhaust manifold 2wd or 4wd
i'm running a 2wd saphy, closed loop msd,greens,l8 ecu,3 bar and a t3 turbo.Is there any advantage putting on a 4wd short exhaust manifold?
Does it lower spool up time or lag?
Your comments would be appreciated.Cheers
Old Jan 27, 2007 | 07:09 PM
rapidcossie's Avatar
rapidcossie
4x4 manifolds are meant to improve response over a 2wd.
dont know if this is a myth or not?
Old Jan 27, 2007 | 07:27 PM
need4speed00001
can you just slacken and rotate the turbine housings on the t3 to fit the manifold or is it more involved? Everything is in the wrong place if not!
Old Jan 27, 2007 | 08:13 PM
Alan s1's Avatar
Alan s1
Yes im sure thats whot i had to do with mine but that was around 18months ago The car never was on the road since so did'nt get to try it out But my m8 said when he had the setup on his it was quick off the mark but topend was'nt as good as the T34
Hope that helps abit
Old Jan 27, 2007 | 08:24 PM
melzieann's Avatar
melzieann
i have a 2wd manifold on my 4x4, i was told it gave you a little more power due to an easyer exhaust gas flow (dont know if true) but i do know the turbo is a lot easyer to remove if you have a 2wd manifold
Old Jan 27, 2007 | 08:59 PM
need4speed00001
Thanks guys,i've got both maifolds but am running the 2wd set up at the moment.I don't know if its worth trying it?
melzieann did you find a difference when you changed to a 2wd manifold?
Old Jan 27, 2007 | 09:17 PM
melzieann's Avatar
melzieann
i found that on the 2wd u have a little more lag (which is slight) but it seems to pull stronger top end
plus the added bonus of the turbo a piece of piss to take off compared with 4x4,
if u do go 2wd make sure u get a turbo damper
Old Jan 27, 2007 | 09:32 PM
need4speed00001
Cheers Simon thanks for the advice
Old Jan 28, 2007 | 10:36 AM
trevCOSS's Avatar
trevCOSS
I think the 4wd is slightly better response but becomes limiting at about 400bhp, It depends what you want to do with the car and how far you want to go, I know people that have changed in both directions.
Old Jan 28, 2007 | 01:54 PM
4 wd one will boost earlier due to shorter path to turbo but not as hard at top end.
jessie_rs
62
Aug 6, 2019 09:27 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
mark r
Sep 29, 2015 07:27 PM
Si B
Sep 12, 2015 06:49 AM
dojj
28
Sep 11, 2015 10:00 PM
