PAS Pipe removal
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I broke the fitting on the pipe that connects the PAS pump to the rack so i need to remove the rest of the pipe.
How do I remove the pipe from the rack. The car is a 2wd cosworth. There is a plate and an 10mm AF bolt securing it to the top of the rack. I have removed this but can see how to remove the pipe.
Any advice??
Also anyone got a pipe i can have?
Thanks Bruce
Any advice??
Thanks Bruce
I thought that was the way to do it. Just never had the balls to give it a good wiggle.
Thanks mate.
Anyone have the said pipe??
Bruce
Thanks mate.
Bruce
I snaped the fitting from the pipe trying to take it out of the pump.
As for the other end of the pipe (going into the rack) Its not wanting to come out. The bolt and the plate are removed but its seized inplace. I think i will wait till I get a new pipe then try and get the old one out.
any other thoughts?
Bruce
any other thoughts?
Bruce
Originally Posted by dojj
twsit it gently
the only thing thats holding it in place if the rubber seal
just make sure you get new ones with the pipe you are replacing it with though
Do you mean buy a brand new rubber seal and fit it to another old pipe? Make sence to fit a new seal if thats the only real thing that makes it liquid tight.
Bruce
if it's broke at one end you might as well break it at the other if it won't come out
worst case scenario is that you wil lhave to remove the rack, but as it's 2wd it's a doddle, pull the 2 bolts out that hold it in place, undo the 10mm bolt that holds the steering shaft to the column just by the bulkhead, undo the tca's and out it comes
with it on the bench you'll have much mroe time to be delicate with it and it might just need a bit of gentle persuasion with a punch to knock it round to break the seal a bit
if you are worried about the other pipe you can thread that through the engine bay while you remove it, not the end of the world if you have to replace it as well but make sure you've got replacements before you go that route
remember to make sure which pipe goes in which hole though
Dojj,
Its ok mate i know what im doing. Was just needing some pointers in how others have done it in the past as mine was seized in.
Bruce
Bruce
jonfoc
16
Sep 11, 2018 05:35 PM
cossie330
Oct 7, 2015 08:22 PM
Fudgey
Sep 17, 2015 01:06 PM
