rst running trouble
Old Jan 27, 2007 | 04:05 PM
rowen20's Avatar
rowen20
Default rst running trouble
got my cab together after buying it with various bits botched up and missing, the problem i have is when i start it it runs fine for 20 to 30 seconds then cuts out and wont start again unless i leave it for 10 mins... tried changeing the pink fuel relay but made no diff... symptoms when it doesnt start are no fuel pump running... the relay cant be faulty though cos it starts and runs my other rs no problems, anyone got any ideas???
Old Jan 27, 2007 | 04:07 PM
rowen20's Avatar
rowen20
also when the ignition is switched on there is a clicking noise coming from the amal valve?? also when it cuts out then the amal valve again clicks a couple of times??
Old Jan 27, 2007 | 04:10 PM
gup's Avatar
gup
when it doesnt start check that you have a spark it could be the distributer thats at fault
Old Jan 27, 2007 | 04:12 PM
lukes1's Avatar
lukes1
ive got a mate who has this prob
Old Jan 27, 2007 | 04:16 PM
rowen20's Avatar
rowen20
gup
ok ill check that cheers
lukes1
has your mate fixed it or not?[/b]
Old Jan 27, 2007 | 04:20 PM
gup's Avatar
gup
also check that the a/f meter flap is moving down smoothly try pushing down slowly when it doesnt start to c if this helps
Old Jan 27, 2007 | 04:22 PM
rowen20's Avatar
rowen20
yea thats the first thing i tried was the metering unit.. put another one on but still doing the same
Old Jan 27, 2007 | 04:32 PM
SafeChav's Avatar
SafeChav
Distributor breaking down.
Check for spark when the fault occurs!
Old Jan 27, 2007 | 04:54 PM
rowen20's Avatar
rowen20
ok ill check that tom, take it the dizzys pretty common problem?
Old Jan 27, 2007 | 05:06 PM
lukes1's Avatar
lukes1
no, he bought an ecu off ebay and all was fine. his gearbox then went so it stood 4 bout a wk. went to fit another box and when he put ignition on the amal valve goes crazy and cranks just wont start.
disconnected the amal valve as hes running a bleed valve neway (amal wiring was left on)
got a good spark and its got a new f-p relay.his pump powers up ok though, havnt cracked off an injector yet though.
Old Jan 27, 2007 | 05:14 PM
lukes1's Avatar
lukes1
rowen--- check out series1- misfire in tech q&a, i forgot to mention what else mine was doing, the cold start valve is nackered but i dont think its related- when i go to my car when its sat ie morning or evening to go home, i put the ignition on and the fuel pump is silent. i crank and it starts and runs for 3- 5 seconds and dies, even though im on the throttle. i then turn ignition on again and the pumps away. it then starts and runs fine. it was the ballyst resistor.i know its not the same but might be worth a try, im sure some1 will tell me if its not!
Old Jan 27, 2007 | 05:15 PM
lukes1's Avatar
lukes1
whatever happens il let u no how mine starts 2moro
Old Jan 28, 2007 | 12:50 PM
rowen20's Avatar
rowen20
k been working with the car... checked for spark, great spark all the time, however... there seems to be no fuel, i had a pipe off the metering unit and when cranking there is no fuel pressure, i tried 3 fuel relays 2 of which def work as they start my other car... could it be the pump as that does make a noise just not every single time you switch the ignition on
Old Jan 28, 2007 | 04:50 PM
SafeChav's Avatar
SafeChav
What colour is your fuel relay?
purple i bet
Old Jan 28, 2007 | 06:17 PM
rowen20's Avatar
rowen20
purplely pink yea... how come?
Old Jan 29, 2007 | 12:22 PM
SafeChav's Avatar
SafeChav
The purple relays won't re-prime until the ignition has been off for about 5 seconds or more, so if your turning the ignition on and off quickly thats why your not always getting a prime
Old Jan 29, 2007 | 06:51 PM
rowen20's Avatar
rowen20
right, ran a wire direct to the pump and gues what pump works for a few seconds then struggles and stops.... so put a new pump on bingo starts and runs.... but wont idle and is switching between 3 and 4 cylinders and engine itself is gettin extremely hot even though temp gauge reads o on the norm....
Old Jan 29, 2007 | 09:23 PM
SafeChav's Avatar
SafeChav
Compression test i say!
Old Jan 30, 2007 | 11:46 AM
rowen20's Avatar
rowen20
yup only one cylinder thats ok... rest are shot...... oh well back to the drawing board! ha ha big thanks to everyone thats helped me here, SafeChav
your class cheers!
Old Jan 30, 2007 | 12:34 PM
SafeChav's Avatar
SafeChav
Oh dear
no worries give us a shout if you need anymore help
JK12
33
Apr 26, 2021 12:09 PM
Billy_RS
Sep 13, 2015 04:17 PM
Eigdoog
Sep 13, 2015 05:46 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
