My S1 problem. pls read.
Old Jan 27, 2007 | 12:25 AM
kurdt5's Avatar
kurdt5
Default My S1 problem. pls read.
ok...before i start spending money on what the garge have said, can i just get some quick advice??
Around Apil last year I changed the Second Injector and injector line after the connecting bit on the banjo broke.
http://smg.photobucket.com/albums/v4...=rst2010-1.jpg
i got the injector of ebay...cheap with the red pipe.
Could the injector be faulty affecting Cylinder 3?? and causing excessive fuel consumption??
or would this problem be the metering head?
Old Jan 27, 2007 | 12:31 AM
Alps Pacino's Avatar
Alps Pacino
Why not take the car to a decent tuner get them to check the injectors out and tune the car. Then take it from there when the tuner tels you your metering heads fucked i'd trust there judgment, but take it somewhere thats reputable and know about rst's
Old Jan 27, 2007 | 08:10 AM
gup's Avatar
gup
could be fella is thier loads of of blue black smoke coming out also does it smell of petrol inside the engine bay
have you checked your plugs to c if the tips are wet or coloured differantly
does the a/f meter flap go down smootly with a bit of resistance
Old Jan 27, 2007 | 11:23 AM
kurdt5's Avatar
kurdt5
goes down smooth. smells of petrol from the exhaust when you turn the car off otrherwise smells ok,
Old Jan 27, 2007 | 04:47 PM
SafeChav's Avatar
SafeChav
Swap injectoprs around and see if the fault moves to another cylinder,
Easy
Old Jan 27, 2007 | 09:15 PM
timturbo's Avatar
timturbo
my series 1 does same when u boot it hard do u know if it leaks little bit petrol?
Old Jan 27, 2007 | 09:21 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
mine used a stupid amount of petrol (mines not an rs but im sure its similar) and had a very small splitt one of the fuel hose's causing ti to drink alot mroe fuel (car went faster i might add) then got it sorted by replacing the fuel lines
Old Jan 27, 2007 | 09:47 PM
timturbo's Avatar
timturbo
yer that makes sense mine isnt that bad and its only when i boost it really hard when leaving it all night in my garage it doesnt leak at all
Old Jan 27, 2007 | 09:48 PM
timturbo's Avatar
timturbo
its not major at all it just leaks few spots
Old Jan 27, 2007 | 10:12 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
its an injection it wont leak while its turned off mate turn the engine on and get it up on a set of ramps ull probably notice it dribbling on to the floor
Old Jan 27, 2007 | 10:17 PM
timturbo's Avatar
timturbo
yer thats what it needs just bought it few days ago fella set it up on standard boost its overfuelling does need settin up
martinmilne
Oct 18, 2019 02:18 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cozzy jeff
Aug 14, 2015 05:46 PM
