cossie problem
Old Jan 25, 2007 | 03:54 PM
wimble's Avatar
wimble
Default cossie problem
ive just put light blue injectors in my 2wd saph
when it is on boost runs fine
but it dosent want to idle and runs bad below 2500rpm jerking
like not enough gas) and trying to die and cut out etc
any advise will be apreciated
sorey about the spelling
Old Jan 25, 2007 | 05:46 PM
I assume you have a correct chip to run these / they do of course have different flow rates to std yellows, so will put mix out, whay chip is it ?
Old Jan 25, 2007 | 06:57 PM
Alvyn's Avatar
Alvyn
as above and also if the chip is correct did you adjust the fuel pressure and co mixture?
Old Jan 26, 2007 | 06:19 PM
Could also be ISCV as this controls ALL OFF BOOST BELOW AROUND 2000RPM, just clean it.
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
