Cutting out!!!!!
Old Jan 23, 2007 | 05:08 PM
kirky's Avatar
kirky
Default Cutting out!!!!!
Was just wondering if anyone has had this problem with there s2!!!
The car starts ok when its cold but after about 10 mins of driving it cuts out when u stop or slow down then wont start untill its cold again!!
The engine is turning over but just wont fire up!!!
HELP PLEASE!!!
Old Jan 23, 2007 | 05:15 PM
Moonie's Avatar
Moonie
Something breaking down when warm, possibly hall sensor in dizzy or maybe fuel relay.
Old Jan 23, 2007 | 05:22 PM
kirky's Avatar
kirky
Fuel relay must b ok coz the pump primes up????
Old Jan 24, 2007 | 01:33 AM
kurdt5's Avatar
kurdt5
i had a similar problem in april last year. Started and drove fine, when i slowed for a junction it cut out.
Sometimes it would start but i would have to keep the revs up or it would stall.
turned out to be the Fuel Pressure Regulator!!! try it, usually get onne on ebay for £4 or £40 rs breakers.
never had a problem after that. took 10 mins to swap over!!!
Old Jan 24, 2007 | 11:00 AM
jimmylaud's Avatar
jimmylaud
i had the same sort of problem but mine didnt cut out just if i switched it off and tried to start it when it was hot it would sometimes not start and that turned out to be the fuel relay
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
