where to put the map sensor...
Old Jan 22, 2007 | 05:12 PM
rscossie86's Avatar
rscossie86
AUSTRIA
Default where to put the map sensor...
Hi there!
I would like to place the map sensor on my 3dr somewhere else, as I want it to be accessible/replaceable more easily!
I guess many of you have done that already, so:
Any recommendations where to put it best?
Or does anyone have pics of his solution he could share? - that would be great!
Thanks alot in advance!
Old Jan 23, 2007 | 07:49 AM
foreigneRS's Avatar
foreigneRS
Testing the future
surprisingly, not many people do relocate the MAP sensor. those that do sometimes put it on a strut brace if fitted.
wherever you put it, make sure it is mounted the same way around as standard (i.e. with nipple pointing down) otherwise you will have problems with condensed water or oil giving a false reading
Old Jan 23, 2007 | 03:36 PM
rscossie86's Avatar
rscossie86
AUSTRIA
Thanks for the advice!
That's a good point - I always thought the mounting direction doesn't
matter, but I didn't think about condensed water...
Thanks again, if I have a proper solution I will post pics...
Old Jan 23, 2007 | 05:42 PM
Alan s1's Avatar
Alan s1
Was thinking the shame thing as im having the Engine Bay painted
Have heard about them being pt on the strut brace but not sure any where else
Old Jan 23, 2007 | 06:35 PM
trevCOSS's Avatar
trevCOSS
mines on the strut brace
Old Jan 23, 2007 | 10:02 PM
Alan s1's Avatar
Alan s1
Well wheres the pics then Buffy
Old Jan 24, 2007 | 09:46 AM
bige's Avatar
bige
the critikal is length of tube from innlet too the Map . on race esc cosw they had 2 mouted in isulated box . du too interferans from ignition wire not supressed ...
Old Jan 24, 2007 | 06:01 PM
trevCOSS's Avatar
trevCOSS
Not great pic but the map sensor is on the right hand side of the strut brace, underneath of course, next to the spare 3 bar map sensor also mounted to the strut brace
Old Jan 24, 2007 | 06:53 PM
Alan s1's Avatar
Alan s1
2 Thats just greedy
Old Jan 24, 2007 | 09:29 PM
rscossie86's Avatar
rscossie86
AUSTRIA
Hey - Thanks for the pic!
That's a very good idea, unfortunately I don't have a strut brace because I never wanted to drill holes in the strut towers...
Maybe I should
Old Jan 27, 2007 | 08:34 AM
cossiestu's Avatar
cossiestu
Got mines on the strut brace too. Sorry, not got a pic at the mo, i need to paint the bracket...
Old Jan 27, 2007 | 12:27 PM
2001ode's Avatar
2001ode
Hi,
On strut, 2 MAP "check to check" ready to spare if necessary.
As "bige" says, lengh of tube is 280 mm. maxi, with original I.D., to avoid bad response from MAP to the ECU.
Regards.
Claude
Old Jan 27, 2007 | 12:33 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Do they fail that often then?
Old Jan 27, 2007 | 04:01 PM
2001ode's Avatar
2001ode
Fail often : no.
But, If you have trouble shooting, you can easely eliminate MAP factor.
Regards,
Claude
Old Jan 28, 2007 | 04:16 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
and when they are under the header tank they always get wet
got point about the pipe length...cos i often thought about putting it inside the car under the dash....nice and dry under there.
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
gavt123
Sep 5, 2015 10:03 AM
