rear wheel bearing on a 2wd saff
i have just done the rear wheel bearings on my saff its all torqued up properly but its really hard to turn the hub theres no driveshaft connected so i thought it should be quite easy to turn can any body help are new wheel bearings tight for a start
it was hard to turn before i even done the hub nut up. done both side now and both are the same
they are just so hard to spin i mean you can only just turn them by hand even with the hub nut loose ive done load of wheel bearings on rs turbos and other stuff but not on a cossie it just feels really strange something just dont seem right with them. there genuine ford bearings ive done just what it says in the work shop manual .
Oct 9, 2015 07:38 PM
