Canadian Needs Help 2WD Cossie
Old Jan 21, 2007 | 12:29 AM
666COS's Avatar
666COS
Default Canadian Needs Help 2WD Cossie
No one in Canada can help me as i have one of the only cossies in the country. I think it may be the alternator as the battery is toast.
Symptoms:
- Harzard flasher barely operate (slowly)
- wipers really slow
- car is back firing and missing
- wont crank over
If it is the alternator i really need a Bosch Part number so i can try and source one locally.
Im desperate for help.
Thanks
Old Jan 21, 2007 | 12:58 AM
jon@work's Avatar
jon@work
Doesn't necessarily sound like the alternator to me. Sounds like it could be the fuse box feeds on the positive battery terminal have corroded or are damaged causing a significant voltage drop. Common problem. The solution is to cut out the "fuseable links" (the first 10 or so inches of the wires to the joint you'll find if you undo the wrapping/sleeving) and replace with the appropriate gauge of new wire.
This could potentially cause all of the above faults including the missfire if the ECU voltage is too low.
SafeChav's Avatar
SafeChav
Get the charging rate checked.
Alternators are easy to fix, its rare to need a new one
Old Jan 21, 2007 | 04:36 PM
666COS's Avatar
666COS
Can you point out what wire this is in the fuse panel and fuse so i can try bypassing it.
Just before it died all the intruments, power accesories, stereo etc... all went dead so i may be leaning towards the main power going into the fuse panel.
but why would my battery be flat?
Thanks for your help gents i really appreciate it.
Old Jan 21, 2007 | 05:34 PM
Alvyn's Avatar
Alvyn
put some jump leads/booster pack on and see if it runs then IF it does it's your alternator that's knackered m8!
ALL the things you have mentioned above will be caused due to low charging rate which IS needed to run the car!
Old Jan 21, 2007 | 08:59 PM
666COS's Avatar
666COS
I found that my alternator wire which attaches to the positive terminal on the battery is loose. would this have cause a failure to charge?
Old Jan 21, 2007 | 11:59 PM
jon@work's Avatar
jon@work
yes
Old Jan 22, 2007 | 04:37 PM
SafeChav's Avatar
SafeChav
YES
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
