Flicking rev counter, squealing(?) coil...help!
Aargh!!
Car was running sweet for about an hour this afternoon then decided to cut out.
After restarting it, it would run for a bit then cut out again.
The rev counter has started goin a bit crazy, and when started it will run for a bit til i put my foot on throttle then it misfires and dies.
What is it that causes the rev counter to go crazy?? Would it be a phase sensor prob, crank sensor, or ign module problem??
Oh, and there is also a squealing noise coming from the coil. Anyone think it might be a faulty coil, or does something else cause it to squeal??
checked and cleaned the wiring to the ign. amp, needed a clean, done that and it didnt make much difference.
Il maybe buy a new ign. amp, anyone know if its a common part for a motor factor to keep??
with my car, anthin is possible at the mo.
It has had a misfire for a while, cleared up for an hour or so today (been stuttering at high revs-managed a 150 run today)then conked out later.
Il swap the amp over on monday and see where i get from there.
The coil is new, as are plugs, leads, dis cap, rotor, coil lead, and almost everything else (Incl phase sensor)
I wiggled the crank sensor when it was running, that seems ok, as do the connections to the coil, so il swap that and if there is still a prob its on to the TPS sensor for swappin.
Im startin to get fed up with the thing TBH, thats over a grand spent and still no further on wi the misfire, and im runnin out of cash.........
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
