2 problems wiv my lovely rs cab
Old Jan 20, 2007 | 07:50 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default 2 problems wiv my lovely rs cab
coming into the 3rd year of owning her,
problem 1
an this mornin i started her up 2 warm up before i set of 4 work an 2 my horror, i saw light blue smoke cumin out of her 4 about 4 mins, then it stopped, it drives an boosts ok any ideas? it use 2 b like a specaled white smoke for about 2 mins for the last 2 years wen i started her up in the mornin
problem 2
wen im driving along an slow down 4 a junction or roundabout an the revs drop under 1000 rpm then drop again to 500 rpm then lower it cuts out, then i use my mommentum 2 bump it 2 fire it bk up, really annoying !! especially wen people look an think he cant drive properly lol
any suggestions/answers etc.. are greatly appreicated
Old Jan 20, 2007 | 08:11 PM
SafeChav's Avatar
SafeChav
Smoking......valve stem seals/turbo oil seals
Cutting out..........probably an air leak.
Old Jan 20, 2007 | 09:42 PM
Alex_86's Avatar
Alex_86
and how long is it since u changes: plugs, plugs cabel, oil, air filter, oil filter, fuel filter?
Old Jan 20, 2007 | 09:47 PM
SafeChav's Avatar
SafeChav
wtf are plugs cabel
Old Jan 20, 2007 | 11:13 PM
Rick's Avatar
Rick
2... too lean.
Old Jan 21, 2007 | 02:26 PM
fast_ford_uk's Avatar
fast_ford_uk
at plugs cable, also known as HT leads lol
Old Jan 21, 2007 | 03:05 PM
Alex_86's Avatar
Alex_86
haha, sorry, meant ignition leads
Old Jan 28, 2007 | 10:07 PM
TuRbO-CaB-LaD
as my car warms up in mornin an smokes blue for 5 mins, an the stem seals need changing........is it best 2 get them dun asap or hav i got a bit of time as im totally skint lol
Old Jan 29, 2007 | 12:28 PM
SafeChav's Avatar
SafeChav
Your not really going to cause damage from worn stem seals but obviously you will use oil.........
Stem seals cost the best part of fuck all and aren't that hard to change really. The special tool will cost you more than the seals and thats only about £8
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
`spotty
Sep 25, 2015 11:41 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
