2 problems wiv my lovely rs cab
coming into the 3rd year of owning her,
problem 1 an this mornin i started her up 2 warm up before i set of 4 work an 2 my horror, i saw light blue smoke cumin out of her 4 about 4 mins, then it stopped, it drives an boosts ok any ideas? it use 2 b like a specaled white smoke for about 2 mins for the last 2 years wen i started her up in the mornin problem 2 wen im driving along an slow down 4 a junction or roundabout an the revs drop under 1000 rpm then drop again to 500 rpm then lower it cuts out, then i use my mommentum 2 bump it 2 fire it bk up, really annoying !! especially wen people look an think he cant drive properly lol :cry: any suggestions/answers etc.. are greatly appreicated :top: |
Smoking......valve stem seals/turbo oil seals
Cutting out..........probably an air leak. |
and how long is it since u changes: plugs, plugs cabel, oil, air filter, oil filter, fuel filter?
2... too lean.
haha, sorry, meant ignition leads
as my car warms up in mornin an smokes blue for 5 mins, an the stem seals need changing........is it best 2 get them dun asap or hav i got a bit of time as im totally skint lol
Your not really going to cause damage from worn stem seals but obviously you will use oil.........
Stem seals cost the best part of fuck all and aren't that hard to change really. The special tool will cost you more than the seals and thats only about £8 ;) |
© 2024 MH Sub I, LLC dba Internet Brands
