info needed on zetec conversion with tb's
hi people, i have got a mk3 escort.with a 1.3 cvh with a 1.6 gearbox carburettor at the moment.
iam going to do a conversion soon....
and need some info, iam going to get a 1.8 zetec and iam going to buy some throttle bodies, would i be able to bolt my 1.6 cvh gearbox up to a 1.8 zetec engine? what flywheel and clutch do i need? do i need to buy some sort of fuel pump for the tb's? what ecu and loom can i use? any info appreciated regards ashley
you'll also need a high pressure fuel pmp to run the injectors in teh TBs and a fuel tank with a return on it.
as for the ECU, I'd suggest having a word with whoever you will be getting to map it and see what they recommend.
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
