s2 Engine Rebuild
Hi,
Just finished rebuilding the engine for my S2 project.
Just a couple of Q's on whats missing from the engine, apart from cambelt tensioner and oil pressure switch.
On the back of the block (inlet side) theres 4 threaed holes in the block, what screws into there? On the bottom if the inlet manifold theres a threaded hole, What screws in there?
And again on the inlet side theres a 2 bolt flange on the head that needs something bolted to it, any ideas?
Theres also a couple of threaded holes on the block on the exhaust side. Anything go in them?
I've hosted a few pics, Did'nt want to post them here as they are huge. Also a pic of the car on 17's albeit with no engine or front bumper yet.
http://www.acelectric.co.uk/engine1
http://www.acelectric.co.uk/engine2
http://www.acelectric.co.uk/engine3
http://www.acelectric.co.uk/engine4
http://www.acelectric.co.uk/engine5
http://www.acelectric.co.uk/engine6
http://www.acelectric.co.uk/car1
Thankyou.
Craig
Thankyou.
Craig
Yes, the 2-bolt flange on the back of the head is used for cars with a mechanical fuel pump, as said above. There should be a blanking plate to go on there.
The port in the Inlet should have an adaptor in it to take the hose from the Auxillary Air Valve (I have one of these with the pipework if you don't have one).
The 2 holes under the Vernier Pulley are for the Cam-belt cover.
On the front of the engine, nothing goes in either of the 2 holes on the block, but the one up by the exhaust ports is for water temp sender for the gauge.
Is that everything?
Is that everything?
Thanks for that, I think that clears everything up.
As mentioned in earlier posts I unfortuantly did not strip the engine down, I'll have a dig around the boxes in the garage for the said Items. I cant remember seeing a blanking place and i might have the auxillary device (what ever it looks like) but not sure on the adaptor.
Edited to add, I've found the auxilarry air adaptor on a spare inlet manifold I had. Why didnt I check there first
Rstar_man
143
Jul 20, 2020 11:16 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
cossiedean84
37
Sep 2, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
