escort cosworth oil pressure gauge
Old Jan 16, 2007 | 10:48 PM
tonyrandl's Avatar
tonyrandl
Default escort cosworth oil pressure gauge
i've hooked up the voltage meter with no probs, the boost gauge has no use but i dont know how the oil pressure gauge works of an RS2000 engine, any ideas?
i take it i will need an escort cosworth sender unit??
Old Jan 18, 2007 | 02:44 PM
Aaroncast's Avatar
Aaroncast
is this lot off an escort cossie?(banana),
are you building a replica?
Old Jan 19, 2007 | 11:11 AM
tonyrandl's Avatar
tonyrandl
yea, they are off an escort cosworth. the car isnt a replica but the interior is a replica - as i like the interior so much!!
Old Jan 19, 2007 | 04:45 PM
MarkN's Avatar
MarkN
You need the Escort Cosworth pressure sensor if they're still available - it's totally different to the switch on a normal Escort. Last time I checked they were about £35 quid...
Old Jan 19, 2007 | 04:50 PM
SafeChav's Avatar
SafeChav
Would a generic oil pressure sender do the job?
Which way round does a cossie sender work?
Old Jan 20, 2007 | 01:14 AM
tonyrandl's Avatar
tonyrandl
asked at my local ford parts and they are now discontinued and i have been told that a generic sender wont be calibrated to the ford gauges therefore they will give a false reading.
does anyone have a sender going for cheap?!!!
Old Jan 20, 2007 | 05:15 PM
SafeChav's Avatar
SafeChav
You could try a generic sender, the times ive heard main dealer people saying bullshit like that when the sad truth is they don't really know the answer!
I doubt the standard one is THAT accurate anyway
Old Jan 21, 2007 | 09:53 AM
MarkN's Avatar
MarkN
I think the wiring is odd on the Escos gauge that might mean it won't work with a generic sender. Rather than having a negative and a positive from the sender it has three wires, two of which are from the sender and one that is negative...
Old Jan 21, 2007 | 11:46 AM
SafeChav's Avatar
SafeChav
All the generic senders ive seen have only 1 connection, its just a variable resistor, dead short to earth is maximum oil pressure!
Old Jan 21, 2007 | 04:57 PM
THE RADMAN's Avatar
THE RADMAN
esc cos ones are £100
Old Jan 21, 2007 | 08:23 PM
tonyrandl's Avatar
tonyrandl
hmm, i'll have to start ringing around the breakers for a sender unit.
if i got one would it go straight into the i4 block or would it need re-tapping?
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
