Head gasket
Old Jan 16, 2007 | 05:21 PM
mattrst90spec's Avatar
mattrst90spec
Default Head gasket
Hi
Im in the middle of putting my zvh back together after a winter rebuild.
What is the best head gasket to use?
My engine is a 1.8 zvh, uprated piston, ported head, stage 3 t3 .48, newman cam with solid lifters, not sure what boost until i get it set up, maybe between 14 & 18 psi.
Old Jan 16, 2007 | 05:28 PM
SafeChav's Avatar
SafeChav
I think felpro are the only people who make these custom gaskets
And Felpro aren't supposed to be that good
Old Jan 16, 2007 | 05:59 PM
grsford's Avatar
grsford
thought you could use the standard ford head gasket on a 1.8 zvh i stand to be corrected though
Old Jan 16, 2007 | 06:10 PM
Chris69's Avatar
Chris69
use the standard un mate as the pistons are 80mm on the 1.8zetec aswell as the rst turbo cvh uns
payen type from ur local motor factors, there very good
Old Jan 17, 2007 | 12:10 PM
mattrst90spec
I've been told a 1.8 zvh uses a standard cvh gasket & a 2.1 zvh needs a special gasket, please correct me if im wrong.
So are you guys saying use a ford gasket rather than an aftermarket job?
Cheers Matt
Old Jan 17, 2007 | 12:12 PM
SafeChav's Avatar
SafeChav
If the bores on a 1.8 are 80mm then a standard gasket is going to be the obvious choice, i don't know much about zetecs
Old Jan 17, 2007 | 04:48 PM
Chris69's Avatar
Chris69
Cheers Matt
spot on mate, i have the haynes manual for the escort zetec and there bore was 80mm
i'ts not quite so easy once ur piston are 85mm as with the 2.1zvh though- like u said its special gasket time
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
