oversize head gasket?
Jan 14, 2007 | 07:03 PM
I'm after a oversize head gasket fot my s2 rs turbo, its running cvh block and head but the pistons are stamped with 85.27 indicating the bore size and the one i just took off has 87mm cylinder bore size.
any ideas so far i'm looking at a felpro item off ebay
Jan 14, 2007 | 07:14 PM
felpro are crap just keep with the std rst headgasket
Jan 14, 2007 | 07:18 PM
but standard pistons are only 80mm will this not cause problems
Jan 15, 2007 | 05:09 PM
nobody use differnt gaskets for oversize pistons????
wot about the peeps with zvh engine, i'm led to beleive there 85mm or there abouts?
Jan 15, 2007 | 05:11 PM
chunt69 , ive got a good idea, lets use an 80mm bore headgasket with an 85mm cylinder bore
Did you get my reply on your other thread mate?
Jan 15, 2007 | 05:33 PM
Re: oversize head gasket?
iv got a felpro gasket on mine with no probs at all an runnin 280hp
Jan 15, 2007 | 06:06 PM
yeah i did
Jan 17, 2007 | 04:51 PM
nobody else know of any other options other than fel-pro????
Jan 17, 2007 | 06:40 PM
For the last time
Measure the size of a stnadard gasket!!! You may be lucky
Jan 17, 2007 | 06:57 PM
For the last time
so do u not know of any other makes then
Jan 17, 2007 | 07:25 PM
Yer
Felpro
Jan 18, 2007 | 08:32 AM
Jan 18, 2007 | 08:47 AM
I have been using a Payen gasket for quite a while with no problems.
Jan 18, 2007 | 12:43 PM
Well you know i always try my best
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
