Electric Windows Stopped Working
Old Jan 14, 2007 | 04:37 PM
spark's Avatar
spark
Default Electric Windows Stopped Working
Was messing around earlier trying to wire up some LEDs off the electric window switchs,
I ran a + and - off the inside of the plug and then pluged the passenger switch back in, it didnt let me open or close the window. So i took the leads back off and retried it but the neither drivers side or passenger side work, They dont light up.
So i checked the 3 fuses but all of them seem fine. What could it be?
Old Jan 14, 2007 | 05:20 PM
Alvyn's Avatar
Alvyn
what car is it? get some jump leads from the battery and run two wires direct to the motors and see if the work if they do then it's either the switches are knackered or it's blown the fuses or there's a break in the wires between the switches and the motors!
Old Jan 14, 2007 | 05:50 PM
spark's Avatar
spark
Its a focus,
I have taken all the fuses out and found out that the Haynes manual says different to what fuse the electric windows is.
Says in the book, 37 40 and 42
It was fuse 56
Old Jan 14, 2007 | 07:00 PM
Alvyn's Avatar
Alvyn
so ALL sorted now
Old Jan 14, 2007 | 08:39 PM
spark's Avatar
spark
Yea but i dont have anymore 25 fuses
So hopefully tomorrow were back in business
Old Jan 15, 2007 | 12:36 PM
SafeChav's Avatar
SafeChav
Put a 20A in for now, you just might find it blows again if you wind both windows up at the same time.
It will not cause any damage, which is the important bit
Old Jan 15, 2007 | 06:28 PM
spark's Avatar
spark
I'll remeber that if i blow these ones i brought today
Old Mar 26, 2012 | 11:51 PM
lukeyboyxxx's Avatar
lukeyboyxxx
Originally Posted by spark
Its a focus,
It was fuse 56
just had the same problem with my x2000 3dr focus
the ford owners manual said the fuses were 44 & 45 so checked and both fine. then systematically checked every fuse and fuse 56 had blown, changed the fuse and "hey presto" the windows work. good ol fords.lol
gordyshreds
20
Aug 10, 2015 02:59 PM
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
