Cossie Brake Lights
Old Jan 14, 2007 | 02:34 PM
timster's Avatar
timster
Default Cossie Brake Lights
Hi guys my brake light check is staying on on the dash,although the lights work fine has anyone else had this problem? thanks paul
Old Jan 14, 2007 | 02:38 PM
rapidcossie's Avatar
rapidcossie
happens on my car too...
also tells me the doors are open when they arent...
Alvyn's Avatar
Alvyn
check the bulbs are the correct type ie single poled ones!
Old Jan 14, 2007 | 02:59 PM
timster's Avatar
timster
I'll check the bulbs now
Old Jan 14, 2007 | 03:06 PM
Alvyn's Avatar
Alvyn
IF it's a saff then you should have 1x bulb that's got a double pin bulb which is for the side light and fog light!
Old Jan 14, 2007 | 03:31 PM
timster's Avatar
timster
Yeah that all checks out,could it be a relay sticking?
Old Jan 14, 2007 | 03:33 PM
timster's Avatar
timster
Forgot to add it is a saff!
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
Red_bull
Aug 9, 2015 08:34 AM
