best cams
Old Jan 13, 2007 | 05:42 PM
rs230's Avatar
rs230
Default best cams
what would be the better cam a piper 285 t or a piper 285 t2 i am running 18 psi
Old Jan 13, 2007 | 05:48 PM
neilrev's Avatar
neilrev
t2 for above 14 psi
Old Jan 13, 2007 | 05:56 PM
KSA-Cossie's Avatar
KSA-Cossie
as above m8,or get a newman cam
Old Jan 13, 2007 | 06:21 PM
SafeChav's Avatar
SafeChav
Neither, a CVH35, or a newman!
(Piper are shit)
Old Jan 13, 2007 | 06:36 PM
neilrev's Avatar
neilrev
i have a piper t2, in what way are they shit? not being funny, just wondered cos mine seems ok
Old Jan 13, 2007 | 07:27 PM
swerv's Avatar
swerv
the piper 285T is far better than the T2 whatever boost your running!
dont listen to the sales talk from piper lol.
Old Jan 13, 2007 | 08:09 PM
cabbyturbo's Avatar
cabbyturbo
Default Re: best cams
get your self a kent35 i cant fault it and its works spot on in mine.....
Old Jan 14, 2007 | 02:05 PM
SafeChav's Avatar
SafeChav
Theres many people that have had Pipers and have learn't the expensive way, a CVH35 is far better as far as dyno results go, and piper cams also wear at an obscene rate.
My mate also had one and they dont have the ball bearing pressed into the centre of the shaft, he couldn't stop oil pissing out of it and all inside the cam belt cover.
Old Jan 14, 2007 | 05:36 PM
addiction's Avatar
addiction
stay away from pooper cams
Old Jan 14, 2007 | 05:38 PM
mentalasanything's Avatar
mentalasanything
As said mate, Kent CVH35, I have one in my RST and it seems spot on. I also have a Kent CVH22 in my XR2 and that runs like a little dream
Lee
Old Jan 14, 2007 | 05:49 PM
Oranoco's Avatar
Oranoco
285T2 is a pants profile. It sacrifices loads of mid range grunt for a small increase in peak power. Absolutely pants.
Kent CVH35 or a Newman , 285T2 only if you want a nice paper weight
Old Jan 14, 2007 | 06:37 PM
Fiecos Dan's Avatar
Fiecos Dan
i found 2 or my 3 Kent cams (2x35's and 1x34) like to wear @ a fast rate.
Never used a piper.
And Newmans is my next route.
Old Jan 14, 2007 | 06:57 PM
SafeChav's Avatar
SafeChav
All CVH cams wear at a fast rate
CVH top ends are shit
Old Jan 14, 2007 | 07:32 PM
JamboRS's Avatar
JamboRS
focus rs 1672
ive had a kent piper and newman,the newman is far better than any of 3
i never had any issues with my piper wearing down fast,but felt the car felt less powerful lower down in the rev range to get top end power where as my newman has more low down grunt and still more top end than the piper,although mine is custom specced so cant comment on there off the shelf item,also when considerin the newman you have to get he solid lifters which will need adjusting often
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
