help! my rst cabby wont start off key
Old Jan 12, 2007 | 10:31 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default help! my rst cabby wont start off key
wen i turn the key, i get flat battery effect, i use jump leads off my gf clio an it starts, wen i turn lights on or put windows down it cuts out, so i tighten the battery bolts that hold the wires on an the positive was slightly loose, so i jump start it again, leave it running wiv lights on, windows go down an it still running, then i turn it off for 1 min, then turn the key an its dead!! any ideas as i start new job 2morrow which is 15 miles away an it requires me driving about an parkin up 4 a bit (windscreen technician) an fixin cracks in peeps windscreens, my boss wont b impressed if im stuck sumwere, plz rs lads i need ur help any ideas a.s.a.p im desperate an need sum ideas,
Old Jan 12, 2007 | 10:38 PM
cabbyturbo's Avatar
cabbyturbo
i hope i can help ya...
do you have a multy meter??????
Old Jan 12, 2007 | 10:41 PM
TuRbO-CaB-LaD
no unfortnately i havnt, but wat do u think it might be at a guess? cheers 4 the reply m8
ps. my alarm works off the fob nice an loud so i dont think i need a new battery unless its got its own back up??
Old Jan 12, 2007 | 10:48 PM
Rick's Avatar
Rick
battery is shagged mate.
Old Jan 12, 2007 | 10:50 PM
cabbyturbo's Avatar
cabbyturbo
sounds to me the battery is not holding charge or the altanator is not charging or over charging and knackerd your batt!!!
if you can get hold of a multi meter from some where it would help alot....
because i need you to check the charge rate....once we know what its charging at i can tell you what the problem is by the volt reading.
Old Jan 12, 2007 | 10:52 PM
cabbyturbo's Avatar
cabbyturbo
hay mister you should never condem anything intill you know for sure you bugger....
Old Jan 12, 2007 | 11:01 PM
TuRbO-CaB-LaD
cheers lads will go garage in mornin an get a reading if i got time b4 i go 2 work
dont fancy drivin my gf's 1.4 clio
Old Jan 12, 2007 | 11:08 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I'd say it's lost charge through the loose lead. . now the battery's flat and its not had a chance to charge from just leaving it running for a short period.
Old Jan 12, 2007 | 11:12 PM
Rick's Avatar
Rick
cabbyturbo
I'd bet my bollcocks on it.....
It it's electrics are working while engine is runnint, then current id coming from alternaotor. If they dont work when engine is off, it HAS to be the battery. If it is that flat due to charging issues, it is now shafted.
Old Jan 12, 2007 | 11:14 PM
vroooom ptssssh
It Wasnt Me!
my battery's been drained beyond belief countless times and it still takes and holds a charge
Old Jan 12, 2007 | 11:22 PM
cabbyturbo's Avatar
cabbyturbo
cabbyturbo
but what if the surpressor has a winding problem in the altanator and creating an open circuit which will give more than the normal ampage of about 1.50 amps to a high 3.0 or 4.0 amp thus creating the drain as it is ignition fed.... anything is possible on a car.....
Old Jan 12, 2007 | 11:23 PM
cabbyturbo's Avatar
cabbyturbo
cabbyturbo
sorry permantly fed.......
Old Jan 12, 2007 | 11:36 PM
Rick's Avatar
Rick
the alternator charge current would overcome it for a short period of time.
Old Jan 13, 2007 | 12:19 AM
vroooom ptssssh
It Wasnt Me!
Alternators dont operate fully until something like 3500Rpm? so if it was sitting idling on a drive. . it wouldnt charge the battery, and depending on how flat the battery was, it could take even longer to start giving it charge!
Old Jan 13, 2007 | 01:26 AM
Rick's Avatar
Rick
proof that incest should be illegal
Old Jan 13, 2007 | 07:31 PM
TuRbO-CaB-LaD
cheers lads, i bumped it again this morning, got it started then took it 4 a drive, parked up turned it off an bk on an it starts off key now, must of bin the loose bolt on the battery, suprised as it was only loose a couple of turns, must of charged bk up wen i drove it about, once again nice one lads
will go garage monday mornin jus 4 peice of mind
Old Jan 13, 2007 | 10:20 PM
vroooom ptssssh
It Wasnt Me!
Ok, so I got the charging RPM wrong. . I was told off a mechanic but everything else I wrote was correct. . .shafted battery did you say rick?
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
EoinXR3
Sep 7, 2015 05:44 AM
muffster
13
Sep 3, 2015 09:40 PM
dlwarrior
Aug 5, 2015 10:19 AM
