is my diff f*$@.....broke????
Old Jan 12, 2007 | 03:25 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default is my diff f*$@.....broke????
right then my wheels are intermitenly locking up...seems to be the rear and it's only happening when i put it in reverse coming of my drive (slight bank) and then if u roll back down in 1st it's locking...not all the time though... when my gearbox was goosed all 4 wheels locked (4x4 saff) dosn't seem to be any noise from anywhere...had it on the ramps today and both rear drive shafts have play, but that wouldn't cause this???? do i just have to wait till it gets worse or should i get the rear diff reconed....cheers Pete
Old Jan 12, 2007 | 03:28 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
i'd check your gear box
Old Jan 12, 2007 | 03:31 PM
pete mcrash
how???? goes in every gear fine and isn't making a racket....
Old Jan 12, 2007 | 03:35 PM
NEIL A's Avatar
NEIL A
Take the diff cover off and check for worn or missing teeth.
Old Jan 12, 2007 | 03:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
have you run it up on the ramps?
does it do it in any other gear?
Old Jan 12, 2007 | 03:48 PM
pete mcrash
....yes pal...it only seems to start when u reverse under load.... the cars 420bhp on a standard but sweet feeling box and diffs (front has plate in)
Old Jan 12, 2007 | 03:50 PM
Turbosystems
Super Moderator
cos the gearboxes are shite roflol
Old Jan 12, 2007 | 03:53 PM
SapphyMike's Avatar
SapphyMike
agricultural i think you called them when i was at your place lol
Old Jan 12, 2007 | 03:54 PM
pete mcrash
forgot to say...coming up to a junction slow down into 1st...i get like a clutch bite then a bang and then it lets me go forward..
Old Jan 12, 2007 | 04:03 PM
Turbosystems
Super Moderator
gear box !!!
the only guarantee you will get with an mt75 is that it will break
the gears were made by play do roflol
Old Jan 12, 2007 | 04:08 PM
xr2i-carl's Avatar
xr2i-carl
is there a risk of the rear locking up at speed?
Old Jan 12, 2007 | 04:10 PM
xr2i-carl's Avatar
xr2i-carl
i would day diff deffo mate
had similar thing with mine, altho didnt lock any wheels thank fuck
was noisy in the end and had play in te shafts
Old Jan 12, 2007 | 04:13 PM
Turbosystems
Super Moderator
none of the transmission on a 4x4 cosworth will take 420 bhp except the rear prop shaft and transfer box
Old Jan 12, 2007 | 05:01 PM
charlie luciano's Avatar
charlie luciano
Default box
None of the transmission on a 4x4 cosworth likes 350 horsies either, mine has chewed her way through two mt75's as well
Oh no its quaife time
Luciano
Old Jan 12, 2007 | 06:13 PM
pete mcrash
just phoned Paul @ ny spares about 2wd conversion...not that bad at all when u can part ex ur 4x4 stuff..... or it visa time and a Dougherty box (spelling)...... i just don't know....
Old Jan 12, 2007 | 08:35 PM
pete mcrash
any more thoughts...cheers
Old Jan 14, 2007 | 07:11 PM
dojj's Avatar
dojj
you sure it's not the clutch breaking up?
i've got a clutch and flywheel in the garage thats more than a little fucked, the springs have broken in that one and it gave the same sort of symptoms
Old Jan 15, 2007 | 04:33 PM
pete mcrash
i really dont know fella....looks like the box is coming out...the clutch has done around 12k so it could be fooked...when the box comes out i'll see the clutch and the box will be checked and only charged if fixed...cheers
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
